.NET
Problem with PaletteSet location in Autocad
24 REPLIES 24
Message 1 of 25
2031 Views, 24 Replies
I'm having problem with chosing PalleteSetSet location in Autocad. No matter what I do, it is always docked on left side of Autocad window. My code is something like this:
PaletteSet ps;
ps = new PaletteSet("blabla", new Guid(System.Guid.NewGuid().ToString("B")));
ps.Style = PaletteSetStyles.NameEditable | PaletteSetStyles.ShowPropertiesMenu |
PaletteSetStyles.ShowAutoHideButton | PaletteSetStyles.ShowCloseButton;
ps.MinimumSize = new System.Drawing.Size(Width,Height);
ps.Size = new System.Drawing.Size(.Width,Height);
ps.DockEnabled = Autodesk.AutoCAD.Windows.DockSides.None;
ps.Add("blabla", new Palette());
ps.Visible = true;
Am I missing something? Edited by: JernejC on Sep 25, 2009 8:42 AM
24 REPLIES 24
Message 2 of 25
Because you use "new Guid()" each time the PaletteSet is created. AutoCAD
persists PaletteSet's location using the GUID assigned to the PaletteSet as
identifier. You should get a fixed Guid value for your PaletteSet.
"JernejC" wrote in message news:6260920@discussion.autodesk.com...
PaletteSet ps;
ps.Visible = true;
Message 3 of 25
Which "new Guid()" is a problem?
1.) System.Guid.NewGuid().ToString("B") or
2.) new PaletteSet("blabla", new Guid(...))
I tried setting fixed Guid in first case but there are still no changes. In second case I don't know if there is any other way...
Message 4 of 25
You need to use the same constant string when
you create the GUID:
{code}
Guid guid = new Guid(""255AA27F-A408-48d5-AA06-F311F3027A9D");
PaletteSet ps = new PaletteSet( "commandname", guid );
You can generate the string for the GUID from Visual Studio's GUIDGEN
tool, which is available from the Tools menu (Tools->Create GUID).
The important thing is that the GUID string must be constant and unique
for each paletteset, and should never change.
Sorry if this post is unreadable, I can assume no responsibility for the
gross incompetence that underlies Autodesk's online discussion group
software.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6263127@discussion.autodesk.com...
Message 5 of 25
Ok, thank you very much.
Message 6 of 25
I have created my GUID, and I'm trying to compile my code.
But always is the same error message:
Error 1 The type 'System.Windows.Interop.IWin32Window' is defined in an assembly that is not referenced. You must add a reference to assembly 'PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'. C:\C#_Projects\test8\PreviewBox\PreviewBox\Class1.cs 30 20 PreviewBox
I have MVS2010 and AutoCAD2013.
Net framework 4.0.
What I should to do?
regards
Message 7 of 25
Alfred.NESWADBA
the message shows you:
>> You must add a reference to assembly 'PresentationCore [...]
have you done that?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 8 of 25
in reply to: Alfred.NESWADBA
Hmm...
no, I did not...
after the addition, works 🙂
I had to also add "static" in this line:
static Guid guid = new Guid("2919D05C-3A64-4098-B465-FCE445CBD1C7");
PaletteSet myPal = new PaletteSet("commandname", guid);
I test this example:
http://blog.smitec.net/posts/autocad-dwg-preview-control/
code:
https://github.com/smitec/AutocadPreviewBox
thank you alfred.
Message 9 of 25
Hmm...
this code is correctly compiled, but if I want to add DWG file, AutoCAD generates an error.
What is wrong?
regards
Message 10 of 25
Alfred.NESWADBA
what I see when I open your project (have not started it at all):
  • you have set the property "local copy" for the references to "yes" ==> that should be "no"
  • how do you debug your project? When going to project-properties you have not set the "external program to start" to your ACAD.EXE or to the ACCORECONSOLE.EXE.
Interesting would be to see what message you get? Upload a screenshot from this message.
- alfred -
Alfred NESWADBA
Message 11 of 25
Where is this position?
OK.
I've added acad.exe.
After Debug (F5), AutoCAD2013 run and show me the error message:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.InvalidCastException: Unable to cast object of type 'Autodesk.AutoCAD.LivePreview.PreviewRuleProvider' to type 'Autodesk.AutoCAD.Internal.IPreviewContextProvider'.
at Autodesk.AutoCAD.LivePreview.PreviewContextService.LoadContext()
at Autodesk.AutoCAD.LivePreview.PreviewContextService.get_ContextProvider()
at Autodesk.AutoCAD.LivePreview.PreviewContextManager.OnIdleInitialize(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Autodesk.AutoCAD.ApplicationServices.Core.Application.OnIdle()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.296 (RTMGDR.030319-2900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 19.0.0.0
Win32 Version: 19.0.55.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcdbMgd.DLL
System
Win32 Version: 4.0.30319.296 built by: RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
I load my DLL (netload) and write PREV.
I see My Palette.
I write LDPRV, and error.
regards
Message 12 of 25
OK. I have found this "local copy".
I changed to "False".
Now, F5 (Debbug) doesn't generate an error, but still is when I write LDPRV.
Message 13 of 25
Alfred.NESWADBA
Ok, then next step is to tell the debugger to stop on all errors. Do that in Visual-Studio ==> pull-down-menu "debug" ==> item "exceptions" (hope that the translation from my German version is ok for that words) and within this dialog check "Common Language Runtime Exceptions".
Now exceptions raised during code will break the debugger and show you the position where the exception occured.
- alfred -
Alfred NESWADBA
Message 14 of 25
It's done.
I have found description this exception:
http://msdn.microsoft.com/query/dev10.query?appId=Dev10IDEF1&l=EN-US&k=k(EHNULLREFERENCE);k(TargetFr...
Do you have any idea what now?
regards
Message 15 of 25
Alfred.NESWADBA
myPreviewBox is never set to an object (never instanciated) as this.Preview is never started.
- alfred -
Alfred NESWADBA
Message 16 of 25
Hmm...
in an example was:
/// <summary>
/// Instance of the Preview box
/// </summary>
PreviewBox myPreviewBox;
I have changed to:
PreviewBox myPreviewBox = new PreviewBox();
and now, the error is here:
maybe this example is incorrect and I never won't run this project?...
regards
Message 17 of 25
Alfred.NESWADBA
does that happen with all drawings? Have you set your AutoCAD to "not save the thumbnails"?
The error seems to raise when the line above does not return a valid object (variable preview). So either there is no image in the file or the function does not return a bitmap.
(have not tried your code, so that's just guessing)
- alfred -
Alfred NESWADBA
Message 18 of 25
When I comment this line:
//grab the thumbnail bitmap and get rid of the white background
System.Drawing.Bitmap preview = dbb.ThumbnailBitmap;
//preview.MakeTransparent(System.Drawing.Color.White);
program run propertly, but view nothing in "My Palette"...
I added Alert in this place:
Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog("\nAlert " + fn.StringResult);
//use the loaded dwg file to update the preview box
myPreviewBox.load_file_preview(fn.StringResult);
and show me path to my DWG file - is correct, eg. "c:\Blocks\My_blok.dwg".
"does that happen with all drawings?" - Yes.
Have you set your AutoCAD to "not save the thumbnails"? - where can I set this?
regards
Message 19 of 25
Alfred.NESWADBA
Command _OPTIONS ==> tab "Open and Save" ==> button "Thumbnail Preview Settings"
- alfred -
Alfred NESWADBA
Message 20 of 25
I have the same like you 🙂
regards
”Boost
