.NET
Distinguished Contributor
Message 1 of 4 (294 Views)
Problem with Jig
294 Views, 3 Replies
06-23-2006 10:42 AM
As you can see, this Class inserts a Text with the actual length of a curve
at the cursorposition.
All works without any problems in wcs. The text rotates like it should. When
i try it in a ucs, the text sometimes rotates a little bit wrong, as i said,
sometimes and not allways.
I have no idea what i can do, any ideas?
code
#region Using directives
using System;
using System.Collections.Generic;
using System.Text;
using System.Threading;
using System.Globalization;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
#endregion
[assembly: CommandClass(typeof(RSNNAcadApp.ExtendedCommands.TestText))]
namespace RSNNAcadApp.ExtendedCommands
class TestText
private double ScaleFaktor = 2.5;
private Curve CurveObj;
[CommandMethod("TestTextEinfüge")]
public void TestTextInsert()
Thread.CurrentThread.CurrentCulture = new CultureInfo("en-us");
Database db = HostApplicationServices.WorkingDatabase;
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
int Luprec = Application.DocumentManager.MdiActiveDocument.Database.Luprec;
try
#region User Input
bool RightObject = false;
//Selection of a Curve
PromptEntityOptions CurveOptions = new PromptEntityOptions("Objekt wählen,
an dem augerichtet werden soll");
PromptEntityResult CurveResult = null;
while (!RightObject)
bool PromptCancel = false;
do
CurveResult = ed.GetEntity(CurveOptions);
} while (CurveResult.Status == PromptStatus.Error);
if (CurveResult.Status == PromptStatus.Cancel)
return;
else if (CurveResult.Status == PromptStatus.OK)
ObjectId entid = CurveResult.ObjectId;
Entity tmpEnt = null;
using (Transaction myT2 = db.TransactionManager.StartTransaction())
tmpEnt = (Entity)myT2.GetObject(entid, OpenMode.ForRead);
CurveObj = tmpEnt as Curve;
if (CurveObj != null)
string ScaleFaktorPrompt = ScaleFaktor.ToString("F" + Luprec.ToString());
ed.WriteMessage(String.Format("\nFaktor = {0}", ScaleFaktorPrompt));
//highlight the entity
CurveObj.Highlight();
bool Flip = false;
while (true)
//Ask for StartPoint
#region Get InsertPoint
InsertBlockJig jig = new
InsertBlockJig(CurveObj.GetClosestPointTo(CurveResult.PickedPoint, false),
CurveObj, ScaleFaktor, Flip);
PromptPointResult InsertResult = (PromptPointResult)ed.Drag(jig);
if (InsertResult.Status == PromptStatus.Cancel | InsertResult.Status ==
PromptStatus.Error)
PromptCancel = true;
break;
else if (InsertResult.Status == PromptStatus.OK)
DBText TextObj = (DBText)jig.GetEntity();
using (Transaction myT = db.TransactionManager.StartTransaction())
BlockTableRecord btr = (BlockTableRecord)myT.GetObject(CurveObj.OwnerId,
OpenMode.ForWrite, false);
btr.AppendEntity(TextObj);
myT.AddNewlyCreatedDBObject(TextObj, true);
myT.Commit();
else if (InsertResult.Status == PromptStatus.Keyword)
else
break;
#endregion
CurveObj.Unhighlight();
if (PromptCancel)
break;
else
CurveOptions.Message = "Falsches Objekt!\nObjekt wählen, das gemessen werden
soll";
#endregion
finally
class InsertBlockJig : EntityJig
Point3d mStartPt, acquiredPoint;
Curve mCurve;
bool mFlip;
double mScale;
Vector3d xAxis;
Matrix3d TextMatrix = new Matrix3d();
CoordinateSystem3d UCS = new CoordinateSystem3d();
Plane UCSPlane = new Plane();
double i;
//DynamicDimensionDataCollection m_dims;
public InsertBlockJig(Point3d Start, Curve Kurve, double Scale, bool Flip)
: base(new DBText())
mCurve = Kurve;
mStartPt = Start;
mScale = Scale;
mFlip = Flip;
i = 0;
((DBText)Entity).Height = mScale;
((DBText)Entity).VerticalMode = TextVerticalMode.TextBottom;
((DBText)Entity).HorizontalMode = TextHorizontalMode.TextCenter;
Update();
m_dims = new DynamicDimensionDataCollection();
Dimension dim1 = new AlignedDimension();
dim1.SetDatabaseDefaults();
m_dims.Add(new DynamicDimensionData(dim1, true, true));
protected override SamplerStatus Sampler(JigPrompts prompts)
JigPromptPointOptions jigOpts = new JigPromptPointOptions();
jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates |
UserInputControls.InitialBlankTerminatesInput |
UserInputControls.NullResponseAccepted);
jigOpts.Message = "\nEinfügepunkt angeben oder neues";
//jigOpts.Keywords.Add("Objekt");
//jigOpts.Keywords.Add("Faktor");
//jigOpts.Keywords.Add("Spiegeln");
//jigOpts.Keywords.Default = "Objekt";
PromptPointResult res = prompts.AcquirePoint(jigOpts);
if (res.Status == PromptStatus.Cancel | res.Status == PromptStatus.Keyword)
return SamplerStatus.Cancel;
acquiredPoint = res.Value;
if (mStartPt != acquiredPoint)
mStartPt = acquiredPoint;
else
return SamplerStatus.NoChange;
return SamplerStatus.OK;
protected override bool Update()
try
Point3d CurvePoint = mCurve.GetClosestPointTo(mStartPt, false);
((DBText)Entity).TextString = mCurve.GetDistAtPoint(CurvePoint).ToString();
xAxis = mCurve.GetFirstDerivative(CurvePoint).GetNormal();
((DBText)Entity).Position = mStartPt;
if (i == 0)
Matrix3d UCSMatrix = ed.CurrentUserCoordinateSystem;
UCS = UCSMatrix.CoordinateSystem3d;
TextMatrix = Matrix3d.AlignCoordinateSystem(mStartPt, Vector3d.XAxis,
Vector3d.YAxis, Vector3d.ZAxis, mStartPt, UCS.Xaxis, UCS.Yaxis, UCS.Zaxis);
((DBText)Entity).TransformBy(TextMatrix);
++i;
UCSPlane = new Plane(mStartPt, UCS.Xaxis, UCS.Yaxis);
ed.WriteMessage("\nWinkel: " +
UCSPlane.GetCoordinateSystem().Xaxis.ToString());
double Angle = xAxis.AngleOnPlane(UCSPlane);
ed.WriteMessage("\nWinkel: " + Angle);
((DBText)Entity).Rotation = Angle;
catch (System.Exception)
return false;
return true;
protected override DynamicDimensionDataCollection
GetDynamicDimensionData(double dimScale)
return base.GetDynamicDimensionData(dimScale);
protected override void
OnDimensionValueChanged(DynamicDimensionChangedEventArgs e)
base.OnDimensionValueChanged(e);
void UpdateDimensions()
DBText MyLine = (DBText)Entity;
AlignedDimension dim = (AlignedDimension)m_dims[0].Dimension;
dim.XLine1Point = MyLine.Position;
dim.XLine2Point = MyLine.Position;
dim.DimLinePoint = MyLine.Position;
public Entity GetEntity()
((DBText)Entity).AlignmentPoint = mStartPt;
return Entity;
Message 2 of 4 (294 Views)
Re: Problem with Jig
06-24-2006 07:53 PM in reply to: RolandF
Is your text insert point xformed to wcs? this can give you incorrect results when working in different ucs's.
Message 3 of 4 (294 Views)
06-25-2006 04:10 AM in reply to: RolandF
Try tis code:
[code]
Point3d mStartPt, acquiredPoint, CurvePoint;
Curve mCurve;
bool mFlip;
double mScale;
double UCSAngle;
Vector3d xAxis;
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
double i;
mCurve = Kurve;
mStartPt = Start;
mScale = Scale;
mFlip = Flip;
i = 0;
((DBText)Entity).SetDatabaseDefaults(HostApplicationServices.WorkingDatabase);
((DBText)Entity).TextStyle = HostApplicationServices.WorkingDatabase.Textstyle;
Update();
jigOpts.UserInputControls = (UserInputControls.Accept3dCoordinates | UserInputControls.InitialBlankTerminatesInput | UserInputControls.NullResponseAccepted);
jigOpts.Message = "\nEinfьgepunkt angeben oder neues";
else
try
CurvePoint = mCurve.GetClosestPointTo(mStartPt, ed.GetCurrentView().ViewDirection,false);
double parm = mCurve.GetParameterAtPoint(CurvePoint);
((DBText)Entity).TextString = mCurve.GetDistanceAtParameter(parm).ToString();
if (i == 0)
TextMatrix = Matrix3d.AlignCoordinateSystem(CurvePoint, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis,
UCS.Origin, UCS.Xaxis, UCS.Yaxis, UCS.Zaxis);
UCSAngle = ((DBText)Entity).Rotation;
++i;
UCSPlane = new Plane(CurvePoint, UCS.Xaxis, UCS.Yaxis);
ed.WriteMessage("\nWinkel: " + UCSPlane.GetCoordinateSystem().Xaxis.ToString());
Vector3d v = xAxis.ProjectTo(UCSPlane.Normal, ed.GetCurrentView().ViewDirection);
double Angle = v.AngleOnPlane(UCSPlane);
ed.WriteMessage("\nUCSAngle: " + UCSAngle);
((Angle + UCSAngle) > Math.PI * 2.0) ? (Angle + UCSAngle - Math.PI * 2.0) : (Angle + UCSAngle);
((DBText)Entity).AlignmentPoint = CurvePoint;
((DBText)Entity).AdjustAlignment(HostApplicationServices.WorkingDatabase);
return false;
return true;
protected override DynamicDimensionDataCollection GetDynamicDimensionData(double dimScale)
protected override void OnDimensionValueChanged(DynamicDimensionChangedEventArgs e)
return Entity;
[/code]
Message 4 of 4 (294 Views)
06-25-2006 11:26 PM in reply to: RolandF
Thank you very much, Alexander!
I've learned so many thing from your example that i was searching for for so
long.
It works like i wanted, no, it is much better.
Roland Feletic
Ingenieurbuero A. Pauser Ges.m.b.H.
http://www.pauser.at
hp workstation xw4200, 3GB
quadro fx1400
AutoCAD 2007, 3DSMax 8.0 SP 2
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
