Problem with AutoCAD 2010 and C#
stardust1611
Message 1 of 18
stardust1611
I have created an application in Visual Studio 2008 (it's not SP1) with C# and it worked perfectly with AutoCAD 2009. But, now, with 2010 I get this error:
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.Exception: The component 'Autodesk.AutoCAD.AcInfoCenterConn.MyAutoCADBalloon' does not have a resource identified by the URI '/AcWindows;component/infocenteracconn/myautocadballoon.xaml'.
at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
at Autodesk.AutoCAD.AcInfoCenterConn.MyAutoCADBalloon.InitializeComponent()
at Autodesk.AutoCAD.AcInfoCenterConn.MyAutoCADBalloon.ShowInfoBalloon()
at Autodesk.AutoCAD.AcInfoCenterConn.InfoCenterManager.AcadApplication_Idle(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Autodesk.AutoCAD.ApplicationServices.Application.raise_Idle(Object value0, EventArgs value1)
at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
Assembly Version: 18.0.0.0
Win32 Version: 18.0.55.0.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/AcdbMgd.DLL
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
msvcm90
Assembly Version: 9.0.30729.1
Win32 Version: 9.00.30729.1
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_e163563597edeada/msvcm90.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework
Assembly Version: 3.0.0.0
Win32 Version: 3.0.6920.1109 (lh_tools_devdiv_wpf.071009-1109)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
AdWindowsInterop
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/AdWindowsInterop.DLL
AdWindows
Assembly Version: 2.1.0.0
Win32 Version: 2.1.123.55
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/AdWindows.DLL
acmgd
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/acmgd.DLL
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.21022.8 built by: RTM
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
AcWindows
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/AcWindows.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/en-US/AcWindows.resources.DLL
acmgd
CodeBase: file:///D:/Central%20Plexus/VB%20Projects/Carpentry/Carpentry/bin/Debug/acmgd.dll
System.Windows.Forms
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
AcTcMgd
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/AcTcMgd.DLL
AcCui
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/AcCui.DLL
Carpentry
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///D:/Central%20Plexus/VB%20Projects/Carpentry/Carpentry/bin/debug/Carpentry.dll
ContextualTabSelectorRules
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/AcWindows.dll
PresentationFramework.Aero
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
ManagedMC3
Assembly Version: 2.20.0.0
Win32 Version: 3.14.1
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/ManagedMC3.DLL
AcWindows
CodeBase: file:///D:/Central%20Plexus/VB%20Projects/Carpentry/Carpentry/bin/Debug/AcWindows.dll
System.Web.Services
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Web.Services/2.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
AcLayer
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/AcLayer.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/AutoCAD%202010/en-US/AcLayer.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
I referenced all necessary files in autocad 2010, and I don't understand what's the problem?
Replies (17)
Message 2 of 18
What does your program do? When does the error occur?
Have you tried stepping through your code line by line to find out which line is triggering this message?
-Mark P.
Message 3 of 18
stardust1611
My program is Carpentry.dll and as you can see on that error list, it gets loaded. The program consists of three functions (autocad commands): for drawing doors, windows and double doors. I access the autocad com object in them. During debugging these functions do not report any error in them, cause they probably don't have any (they worked in AutoCAD 2009). I also implemented interface IExtensionApplication, and because of that i have two functions: Initialize and Terminate. Terminate contains no code, and initialize truggers yet another function: loadtoolbars. This function loads my customization cuix file with ads_queueexpr, and it doesn't appear to be triggering the error, because the customization file loads fine and the toolbar appears, and i get the message in the editor that the customization file was loaded successfully. The error appears after everything has been loaded and after the Ribbon command appears in the editor, and after the ribbon has been completely loaded. The error can be ignored by pressing the continue button, and then i try to trigger my commands door, window and ddoor but i get "Unknown command".
Message 4 of 18
stardust1611
I found out in the help files that AcInfoCenterConn class belongs to this namespace: Autodesk.AutoCAD.AcInfoCenterConn.AcInfoCenterConn, and I tried to add it but that gives me following error message: The type or namespace name 'AcInfoCenterConn' does not exist in the namespace 'Autodesk.AutoCAD' (are you missing an assembly reference?). It seems that I'm missing some dll in the references. Which one would that be?
Message 5 of 18
Google AcInfoCenterConn
///kdub
style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
I
Message 6 of 18
stardust1611
In autocad 2010 there are missing two assemblies that were present in autocad 2009: AcInfoCenterConn.dll and AdInfoCenter.dll. I found out that namespace AcInfoCenterConn contains IExtensionApplication interface and it's methods: Initialize() and Terminate(). But there was no need to add reference to AcInfoCenterConn.dll and AdInfoCenter.dll in AutoCAD 2009 and it worked well. Did these two assemblies change name?
Message 7 of 18
Those DLLs no longer exist in AutoCAD 2010. The components that were in them
are now in the main interop DLLs, but the error message you show suggests
that they're still looking for the resources as if they were still in those
DLLs.
Looks like a bug.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:[email protected]...
Message 8 of 18
stardust1611
Could this be solved by adding the reference to correct dll where this namespace is located? If yes, what are the names of these main interop dlls you mentioned? If this really is a bug, whome should i inform about it? Thanks.
Message 9 of 18
You should already have a reference to the DLL that contains
those components (acmgd.dll).
I don't think you can fix this, and I'm not even sure what's
causing it.
Thanks.
Message 10 of 18
stardust1611
The info center is in AcWindows.dll. I found out that on this page: http://discussion.autodesk.com/forums/message.jspa?messageID=6157330 , where even you participated in the discussion just 6 days ago. I added the reference to it, and now i have that namespace, but to no avail. The error is still there. Edited by: Stardust1611 on Apr 21, 2009 6:59 PM
Message 11 of 18
stardust1611
Mr Tanzillo, have you perhaps found out solution to this problem?
Message 12 of 18
Did you read my last reply?
Mr
problem?
Message 13 of 18
stardust1611
Hello again mr. Tanzillo. It appears that this was not a bug at all. I noticed I didn't set Copy Local to false on some of my references, and when I did that, the error disappeared. Thanks anyways.
Message 14 of 18
Dave_S
I had a similar problem and found this thread by doing a search on myautocadballoon. Tony gave me a hint when Tony said that the DLL no longer exists in AutoCAD 2010. I disabled all my third party apps to no avail. Then discovered i had a path set to my old AutoCAD 2009 support directory. I deleted this from my support path and the problem went away. I re-enabled my third party apps and everything works fine.
Thanks.
Message 15 of 18
you can add require dll
Message 16 of 18
stardust1611
Hello Tony,
could you try to help with one ancient thread that was not solved? This is the thread: http://discussion.autodesk.com/forums/thread.jspa?messageID=6296180&
Message 17 of 18
Can't really tell you much without seeing the code.
Supporting AutoCAD 2000 through 2010
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
Hello Tony,
the thread:
Message 18 of 18
Hi everybody,
the same error appears within AutoCAD2011 and Visual Studio 2010. After that AutoCAD 2011 doesnt work properly.
The same code works with Sharpdevelop 3.2 and AutoCAD 2010 well.
Regards Jürgen.
