.NET
Valued Contributor
rick_hgy
Message 1 of 5 (701 Views)
Problem using acedTrans for UCS to DCS in AutoCAD 2013
701 Views, 4 Replies
04-11-2012 11:10 PM
Dear All,
We using acedTrans function in AutoCAD 2012 and previous version, and it worked fine.
[DllImport("acad.exe", CallingConvention=CallingConvention.Cdecl, EntryPoint="acedTrans")] static extern int acedTrans(double[] point, IntPtr fromRb, IntPtr toRb, int disp, double[] result);
Kean had a post introduct this code: http://through-the-interface.typepad.com/through_the_interface/2007/10/plotting-a-wind.html
but after we migrate it to AutoCAD 2013, there is a error message:  Unable to find an entity point named 'acedTrans' in dll 'acad.exe'
We can't find the reference sample from the objectARX for 2013 version, it's any change for 2013?
Thanks!
Rick
_gile
Message 2 of 5 (699 Views)
Re : Problem using acedTrans for UCS to DCS in AutoCAD 2013
04-11-2012 11:25 PM in reply to: rick_hgy
Try replacing "acad.exe" with "accore.dll".
Gilles Chanteau
Active Contributor
huaxiamengqing
Message 3 of 5 (529 Views)
Re: Problem using acedTrans for UCS to DCS in AutoCAD 2013
10-10-2012 07:44 PM in reply to: rick_hgy
thank very much!its exactly what l want!
Active Contributor
Andrey_Bushman
Message 4 of 5 (114 Views)
06-10-2014 12:15 PM in reply to: huaxiamengqing
Additional info for AutoCAD 2015.
Its name is _acedTrans in AutoCAD 2015 x86, and acedTrans in AutoCAD 2015 x64. So, as a variant:
#if AUTOCAD_NEWER_THAN_2012
    const String acedTransOwner = "accore.dll";
#else
    const String acedTransOwner = "acad.exe";
#endif
#if AUTOCAD_NEWER_THAN_2014
    const String acedTrans_x86_Prefix = "_";
#else
    const String acedTrans_x86_Prefix = "";
#endif
    const String acedTransName = "acedTrans";
    [DllImport(acedTransOwner, CallingConvention = CallingConvention.Cdecl,
            EntryPoint = acedTrans_x86_Prefix + acedTransName)]
    static extern Int32 acedTrans_x86(Double[] point, IntPtr fromRb,
      IntPtr toRb, Int32 disp, Double[] result);
    static extern Int32 acedTrans_x64(Double[] point, IntPtr fromRb,
    public static Int32 acedTrans(Double[] point, IntPtr fromRb, IntPtr toRb,
      Int32 disp, Double[] result) {
        if(IntPtr.Size == 4)
          return acedTrans_x86(point, fromRb, toRb, disp, result);
        else
          return acedTrans_x64(point, fromRb, toRb, disp, result);
_________________________________________
AutoCAD .Net Laboratory
Active Contributor
Andrey_Bushman
Message 5 of 5 (99 Views)
06-10-2014 01:34 PM in reply to: Andrey_Bushman
Misprint for acedTrans_x64. This is right:
            EntryPoint = acedTransName)]
You are not logged in.
Ask the Community
