.NET
Problème with AutoCAD 2009 .Net DLL Autoload
4 REPLIES 4
wperaud
744 Views, 4 Replies
I would like my .net DLL to be Autoloaded at Autocad 2009 startup.
I followed this solution, http://through-the-interface.typepad.com/through_the_interface/2006/09/automatic_loadi.html ,
but nothing happens when I start Autocad.
I joined my registry key, as text.
Could someone help me please ?
Thank you.
4 REPLIES 4
_gile
in reply to: wperaud
Salut,
Regarde ici :
http://www.acadlabs.com/viewtopic.php?f=18&t=44
Gilles Chanteau
GileCAD
GitHub
wperaud
I made a few tests, when there are keys in the registry
- Netload doesn't LOAD my DLL
- AutoCAD close with a error
So, I add, into the loaded class, a messageBox at the beggining of the public void Initialize() method.
As this messageBox is show at AutoCAD startup, It shows that the DLL is auto-loaded 🙂
But, the loading stops when using some AutoCAD Object, such as :
{code}RibbonPaletteSet paletteSet = Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet;{code}
{code}Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.RibbonControl.Tabs.Add(tab);{code}
The only thing I need, is a custom tab being loaded at Autocad 2009 startup.( tab defined by the code, thanks to a Ressource Dictionnary)
The object that make my load stops is, as we can see into the code, Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSet.
Has someone any idée ?
wperaud
I found a solution :
In the Initialise() method, i add an EventHandler :
{code}
Autodesk.AutoCAD.Ribbon.RibbonServices.RibbonPaletteSetCreated += new EventHandler(RibbonServices_RibbonPaletteSetCreated);
{code}
Now, I just can add all my actions in the following method :
{code}
void RibbonServices_RibbonPaletteSetCreated(object sender, EventArgs e)
{code}
mamj
I followed the instruction to, and had the same result.
I fixed it by replacing the double slash in the LOADER string...
C:\\Release\\ACADProject.dll became C:\Release\ACADProject.dll
”Boost
