.NET
Printer configuration search path
1 REPLY 1
e.g.
398 Views, 1 Reply
I need to set the Printer Configuration Search Path and the Plot Style Table Search Path. Currently I am using COM but the issue I have is that I need to run the same application on 2 different machines, one has only Autocad 2010 (xp-32bit), the other has both Autocad 2010 and Autocad 2012(win7-64bit) and I've got some difficulty to have it running.
Can I set those paths without using COM?
Thanks for your help.
e.g.
1 REPLY 1
Alfred.NESWADBA
in reply to: e.g.
you may read the values from the registry (within the active profile).
The other option would be to use COM-access with the reflection-methods as Hallex showed it >>>here<<<, that makes it possible to use COM without need to reference the ActiveX components/interfaces (activation of late-binding is then necessary I think)
HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
