.NET
Valued Contributor
ognyandim
Message 1 of 4 (624 Views)
Preview of outside DWG in AutoCAD 2008 64 bits
624 Views, 3 Replies
11-09-2010 04:32 AM
Hi all,
I have a acThumb.ocx and it works fine on 32 bits AutoCAD 2008.
Now I need to have the same functionality in 64 bits in AutoCAD 2008.
I have read all the forum threads around and there were examples like this one :
http://forums.autodesk.com/t5/NET/Save-preview-to-file/m-p/1351983
and this one :
http://forums.autodesk.com/t5/NET/block-image/td-p/1476488
and here :
http://www.caddzone.com/BlockIconSample.zip
... and more.
The problem is that Tonys http://www.caddzone.com/BlockIconSample.zip works fine when the block is already inside the current dwg. I tried to modfiy the db like this: (but it does not work)
[code]
// this - does not work
Database db = new Database(false, true);
string sourceDrawing = "C:\\134160.dwg";
 db.ReadDwgFile(sourceDrawing, System.IO.FileShare.Read, true, "");
//instead of this which works fine
  //Database db = AcadApp.DocumentManager.MdiActiveDocument.Database;
[/code]
The DWG is WBLOCK-created block and I suppose that it  does not have preview before loading into MDIActiveDocument. I want to gets its preview witho
Old acThumb.ocx does the work, but I cant find a way to do this in AutoCAD 2008 in 64 bits.
Can you help me with a suggestion or code?
Valued Contributor
ognyandim
Message 2 of 4 (589 Views)
Re: Preview of outside DWG in AutoCAD 2008 64 bits
11-10-2010 12:41 AM in reply to: ognyandim
Does anybody have an idea about this issue?
Valued Mentor
Jeffrey_H
Message 3 of 4 (581 Views)
11-10-2010 01:49 AM in reply to: ognyandim
Try
Database db = new Database(false, false);/////When you set to true associating this database to the current document
db.ReadDwgFile("C:\\134160.dwg",FileOpenMode.OpenForReadAndReadShare, False, ""); /// This should not really matter
Bitmap bitmp = db.ThumbnailBitmap
You can also find your answers @ TheSwamp
Valued Contributor
ognyandim
Message 4 of 4 (536 Views)
11-15-2010 02:33 AM in reply to: ognyandim
You are not logged in.
Ask the Community
