.NET
Possible Missing Reference for VBA to VB.Net code????? Help
1 REPLY 1
gr8ysun
362 Views, 1 Reply
I keep getting the error listed below when I try to compile this code in Visual Studio Express as a VB.Net application.  I'm no coder but was trying to use some VBA code I found and transfer it over to VB.Net.  Anyone have an idea as to what I'm missing?
Error 1 Cannot embed interop type 'SymBBAuto.IAcadObjectEvents_Event' because the source interface 'Autodesk.AutoCAD.Interop.Common.IAcadObjectEvents' referenced by its ComEventInterfaceAttribute cannot be found. C:\Users\cgmcneil\documents\visual studio 2012\Projects\BOM Project\BOM Project\Class1.vb 40 23 BOM Project
Imports System
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Runtime
Imports Microsoft.VisualBasic.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Interop.Common
Imports SymBBAuto
Public Class Class1
   <CommandMethod("GetColumnsPartRef")> _
   Public Sub GetColumnsPartRef()
          Dim acadapp As Autodesk.AutoCAD.Interop.AcadApplication
          acadapp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
          Dim acadDoc As AcadDocument = acadapp.ActiveDocument
          Dim symbb As McadSymbolBBMgr
          symbb = acadapp.GetInterfaceObject("SymBBAuto.McadSymbolBBMgr")
          'Get BOM manager
          Dim gBomMgr As IMcadBOMMgr
          gBomMgr = symbb.BOMMgr
           'Get standard manager
          Dim stdMgr As McadStandardMgr
          stdMgr = symbb.StandardMgr
          'Get the current standard
          Dim currentStd As McadStandard
          currentStd = stdMgr.CurrentStandard
          'Get BOM Standard
          Dim BOMStd As McadBOMStandard
          BOMStd = currentStd.BOMStandard
          'Get all BOM visible columns from BOM standard
          Dim BOMcol As McadColumnDefinitions
          BOMcol = BOMStd.Columns
          For i As Integer = 0 To BOMStd.Columns.Count - 1
                MsgBox(i + 1 & ". COLUMN NAME -> " & BOMStd.Columns.Item(i).Name & vbLf & _
                              i + 1 & ". COLUMN CAPTION -> " & BOMStd.Columns.Item(i).Caption)
          Next
     End Sub
End Class
1 REPLY 1
Jeff_M
in reply to: gr8ysun
Not sure, but try setting Embed Interop Types to false in the SymBBAuto reference properties.
Jeff_M, also a frequent Swamper
”Boost
