.NET
Polyline with Arc
6 REPLIES 6
ditran7577
1761 Views, 6 Replies
Polyline with Arc
Hi everyone,
I'm having a problem when I create polyline with arc using vb.net. The arc is a quarter of ellipse. Please see picture below for detail.
Thanks any helps.
6 REPLIES 6
An ellipse is not an arc and cannot be joined to a polyline.
Maybe you can try to facet the ellipse. With this you turn the ellipse into a polyline that's almost (but not exactly!) following the same path as the ellipse.
Here's an excellent explanation, including some code...
http://through-the-interface.typepad.com/through_the_interface/2009/12/faceting-autocad-curves-using...
How about SPLINE! Can we create a spline like blue arc (in picture)?
_gile
in reply to: ditran7577
Have a look at the GeometryExtensions library, specialy the PolylineSegment and PolylineSegmentCollection classes.
There's an example on how to use them here.
Gilles Chanteau
GileCAD
GitHub
ditran7577
in reply to: _gile
Thank for help. Are there any way to draw only a quarter of ellipse.
_gile
You can set the StartAngle and EndAngle properties of the Ellipse instance. Angles are measured in radians CCW from the MajorAxis vector.
Gilles Chanteau
GileCAD
GitHub
ditran7577
in reply to: _gile
Thank Gilles. This is exactly what I’m looking for.
”Boost
