.NET
PointPromptResult and Point2D Compatibility
3 REPLIES 3
tcorey
314 Views, 3 Replies
Dim ptll AsPromptPointResult
Dim ptlr AsPoint2d
ptll = acDoc.Editor.GetPoint(PrmtPointOpt)
ptlr = PolarPoints(ptll, 0, desFrameWid)
The code above creates a point called ptll using the GetPoint function. The code that creates ptlr wants a Point2d as its basepoint arguement, but ptll is a PromptPointResult and causes an error when I plug it in as basepoint.
Does anyone know how to convert a PromptPointResult into a Point2D?
TIA,
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
3 REPLIES 3
tcorey
in reply to: tcorey
Never mind, I figured it out. I guess I should think just a little before posting.
To solve it, I created X,Y variables from the promptpointresult object and substituted those into the x,y values of a point2d object, and then used that as the basepoint.
Tim Corey
Redding, CA
Alfred.NESWADBA
in reply to: tcorey
look to this (and don't forget to declare varaibles so you get the message of some issues at the moment you write your code!
'assuming you have the following statement on top of your codefile
Imports Autodesk.AutoCAD
Dim ptll as EditorInput.PromptPointResult ptll = acDoc.Editor.GetPoint(PrmtPointOpt) if ptll.Status = EditorInput.PromptStatus.OK then 'so we know the query for the point was not ESCaped dim pt as Geometry.Point3D = ptll.Value 'now you can goon
- alfred -
[EDIT] ok, to late [/EDIT]
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
tcorey
in reply to: tcorey
Thanks, Alfred.
Tim Corey
Redding, CA
”Boost
