.NET
Active Contributor
gulzar25
Message 1 of 5 (355 Views)
Point on polygon
355 Views, 4 Replies
07-30-2013 04:34 AM
I want to check if a point lies inside a polygon and i also want to check if that particular point lies on the polygon.
Gulzar
mzakiralam
Message 2 of 5 (347 Views)
Valued Contributor
dynamicscope
Message 3 of 5 (301 Views)
Re: Point on polygon
07-30-2013 07:38 PM in reply to: gulzar25
I use the following algorithm. Try this.
public struct Point
	public double x;
	public double y;
	public Point(double _x, double _y)
		x = _x;
		y = _y;
// wn_PnPoly(): winding number test for a point in a polygon
//      Input:   P = a point,
//               V[] = vertex points of a polygon V[n+1] with V[n]=V[0]
//      Return:  wn = the winding number (=0 only if P is outside V[])
public static bool IsInPolygon(Point[] V, Point P, int n)
	int wn = 0;    // the winding number counter
	// loop through all edges of the polygon
	for (int i = 0; i < n; i++)
	{   // edge from V[i] to V[i+1]
		if (V[i].y <= P.y)
		{         // start y <= P.y
			if (V[i + 1].y > P.y)      // an upward crossing
				if (isLeft(V[i], V[i + 1], P) > 0)  // P left of edge
					++wn;            // have a valid up intersect
		else
		{                       // start y > P.y (no test needed)
			if (V[i + 1].y <= P.y)     // a downward crossing
				if (isLeft(V[i], V[i + 1], P) < 0)  // P right of edge
					--wn;            // have a valid down intersect
	if (wn == 0)
		return false;
	else
		return true;
// isLeft(): tests if a point is Left|On|Right of an infinite line.
//    Input:  three points P0, P1, and P2
//    Return: >0 for P2 left of the line through P0 and P1
//            =0 for P2 on the line
//            <0 for P2 right of the line
//    See: the January 2001 Algorithm "Area of 2D and 3D Triangles and Polygons"
internal static double isLeft( Point P0, Point P1, Point P2 )
	return ( (P1.x - P0.x) * (P2.y - P0.y) - (P2.x - P0.x) * (P1.y - P0.y) );
Active Contributor
gulzar25
Message 4 of 5 (287 Views)
07-30-2013 10:51 PM in reply to: gulzar25
Thanks for the reply.
I tried using the above code but it gives same results for point on polygon and for point inside polygon.Is there any way to differentiate.
Gulzar
Valued Contributor
dynamicscope
Message 5 of 5 (283 Views)
07-31-2013 12:38 AM in reply to: gulzar25
Oh, didn't know you also wanted to check if the point is on polygon.
I guess you can just check that with the linear equation of every side of the polygon.
Or you can use GetDistAtPoint(Point3d point) method of the Curve entity.
It throws an InvalidInput Exception if the point is not on the curve entity. :smileyhappy:
You are not logged in.
Ask the Community
