.NET
Point Calculation from Xreference
2 REPLIES 2
330 Views, 2 Replies
I have a point from an xref and I need to find the corresponding point in the current CAD file.
The xref is offset from 0,0,0 and rotated in and from the XY plane.
I have the original point and the xreferences attachment point and normal and rotation but my calculations always come up with an error.
Can anyone advise how I do this?
Regards
2 REPLIES 2
StephenPreston
An Xref is hel in a BlockTableRecord, and added to model/paper space as a BlockReference - just like any other block - so the same technique discussed here will work for you too:http://forums.autodesk.com/t5/NET/How-to-capture-the-real-point-of-a-line-within-a-block/m-p/3141904....
Cheers,
Stephen Preston
Autodesk Developer Network
in reply to: StephenPreston
Thanks, I wished I had found that yesterday.
”Boost
