.NET
Plotting to PNG error.
0 REPLIES 0
Message 1 of 1
jprisbe
507 Views, 0 Replies
I've written a .NET dll (C#) that loads a dwg file, runs commands to set _VPOINT, VSSHADOWS, VSMATERIALMODE, DEFAULTLIGHTING, _MaterialMap, _pointlight, _distantlight and then zoom extents.
I then plot the file to a 240x240 png file.
If I setthe
PlotSettings.ShadePlot to PlotSettingsShadePlotType.Rendered, I get a unhandled exception when calling
PlotEngine.BeginGenerateGraphics;
Do I need to set some other PlotSettings value in order to set ShadePlot to Rendered?
It works if I don't use rendered.
Code below...
public
void PlotPNG240x240(string outputFolder, LogfilelogFile)
string fileName = "";
Autodesk.AutoCAD.EditorInput.
Editor ed = null;
try
AcadApplication app = AcadApp.AcadApplication asAcadApplication;
app.ZoomExtents();
Document openDoc = AcadApp.DocumentManager.MdiActiveDocument;
fileName = openDoc.Name;
Autodesk.AutoCAD.ApplicationServices.Documentdwg;
dwg = AcadApp.DocumentManager.MdiActiveDocument;
ed = dwg.Editor;
ed.WriteMessage(string.Format("\nProcessing {0}\n", fileName));
Autodesk.AutoCAD.DatabaseServices.Databasedb;
db = dwg.Database;
Autodesk.AutoCAD.DatabaseServices.TransactionManagertransManager;
Autodesk.AutoCAD.DatabaseServices.Transactiontrans;
transManager = dwg.TransactionManager;
trans = transManager.StartTransaction();
// We'll be plotting the ModelSpace layout
BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
Layout lo = (Layout)trans.GetObject(btr.LayoutId, OpenMode.ForRead);
// We need a PlotInfo object linked to the layout
PlotInfo pi = newPlotInfo();
pi.Layout = btr.LayoutId;
// We need a PlotSettings object based on the layout settings which we then customize
PlotSettings ps = newPlotSettings(lo.ModelType);
ps.CopyFrom(lo);
ps.PlotHidden = true;
ps.ShadePlot = PlotSettingsShadePlotType.Rendered;
ps.ShadePlotResLevel = ShadePlotResLevel.Normal;
// The PlotSettingsValidator helps create a valid PlotSettings object
PlotSettingsValidator psv = PlotSettingsValidator.Current;
psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
psv.SetUseStandardScale(ps, true);
psv.SetPlotCentered(ps, true);
psv.SetPlotRotation(ps, PlotRotation.Degrees000);
psv.SetPlotConfigurationName(ps, "PublishToFSL240x240 PNG.pc3", null);
psv.RefreshLists(ps);
// must call this before setting current style sheetStringCollectionmedialist = psv.GetCanonicalMediaNameList(ps);
psv.SetCanonicalMediaName(ps, medialist[0]);
// choose the default media
psv.SetCurrentStyleSheet(ps, "Grayscale.ctb");
// We need to link the PlotInfo to the PlotSettings and then validate it
pi.OverrideSettings = ps;
PlotInfoValidator piv = newPlotInfoValidator();
piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
piv.Validate(pi);
if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting)
PlotEngine pe = PlotFactory.CreatePublishEngine();
using(pe)
pe.BeginPlot(null, null);
// We'll be plotting a single document
pe.BeginDocument(pi, openDoc.Name, null, 1, true, outputFolder + "\\" + Path.GetFileNameWithoutExtension(fileName) + ".png");
PlotPageInfo ppi = newPlotPageInfo();
pe.BeginPage(ppi, pi, true, null);
pe.BeginGenerateGraphics(null);
pe.EndGenerateGraphics(null);
// Finish the sheet
pe.EndPage(null);
// Finish the document
pe.EndDocument(null);
// And finish the plot
pe.EndPlot(null);
ppi.Dispose();
pe.Destroy();
pe.Dispose();
piv.Dispose();
psv.Dispose();
ps.Dispose();
pi.Dispose();
trans.Commit();
trans.Dispose();
transManager.Dispose();
catch (Autodesk.AutoCAD.Runtime.ExceptionexAcad)
logFile.WriteLine(string.Format("PlotPNG - Error plotting: {0}", Path.GetFileNameWithoutExtension(fileName)));
logFile.WriteLine(string.Format("{0}", exAcad.Message));
MessageBox.Show(exAcad.Message, "STCPlotToPNG", MessageBoxButtons.OK, MessageBoxIcon.Error);
catch (System.ExceptionexSystem)
logFile.WriteLine(string.Format("{0}", exSystem.Message));
MessageBox.Show(exSystem.Message, "STCPlotToPNG", MessageBoxButtons.OK, MessageBoxIcon.Error);
finally
0 REPLIES 0
”Boost
