• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Plot dwg with centered attributes - problem
    201 Views, 10 Replies
    01-16-2012 06:46 AM
    My routine inserts in modelspace different blocks with attributes in it with justification "Center".
    After the blocks are inserted and the attributes are filled, it all looks good in Autocad.
    Then I want to plot the DWG.
    The problem is that the centered attributes in the plot are then justified to "Left" ????
    When I run my routine the second time in the same drawing then it goes well.
    Why is that? Am I missing something?
    It looks like the attributes or blockreference isn't updated well in the database after insert?
    Geert
    Code:
          public static BlockReference InsertBlockReference(Database database, string filename, string blockname, Point3d
        insertionpoint, Scale3d scalefactor)
                 using (DocumentLock documentLock = Active.Document.LockDocument())
                     using (Transaction transaction = database.TransactionManager.StartTransaction())
                         ObjectId newBlockID = new ObjectId();
                         BlockTable blockTable = (BlockTable) database.BlockTableId.GetObject(OpenMode.ForRead);                     //Modelspace
                         using (BlockTableRecord blockTableRecord = (BlockTableRecord)transaction.GetObject
        (database.CurrentSpaceId, OpenMode.ForWrite))
                            if (blockTable.Has(blockname))
                                 newBlockID = blockTable[blockname];
                             else
                                 newBlockID = GetBlockIDFromReadDwgFile(database, filename, blockname);
                            BlockReference newBlockReference = new BlockReference(insertionpoint, newBlockID);
                             newBlockReference.ScaleFactors = scalefactor;
                             blockTableRecord.AppendEntity(newBlockReference);
                             transaction.AddNewlyCreatedDBObject(newBlockReference, true);
                            //Attributes in Block
                             BlockTableRecord newBlockTableRecord = GetBlockTableRecord(newBlockID, blockname);                         if (newBlockTableRecord.HasAttributeDefinitions)
                                 AddAttributesToNewBlockReference(newBlockTableRecord, newBlockReference);
                             transaction.Commit();
                             return newBlockReference;
           private static void AddAttributesToNewBlockReference(BlockTableRecord blocktablerecord, BlockReference
        blockreference)
                 using (Transaction transaction = blockreference.BlockId.Database.TransactionManager.StartTransaction())
                     foreach (ObjectId objectId in blocktablerecord)
                         Entity entity = (Entity) transaction.GetObject(objectId,OpenMode.ForRead);
                         if (entity is AttributeDefinition)
                             AttributeDefinition newAttributeDefinition = (AttributeDefinition)entity;
                             AttributeReference newAttributeReference = new AttributeReference();
                             newAttributeReference.SetAttributeFromBlock(newAttributeDefinition, blockreference.BlockTransform);                         ObjectId attributeReferenceID = blockreference.AttributeCollection.AppendAttribute
        (newAttributeReference);
                             transaction.AddNewlyCreatedDBObject(newAttributeReference, true);
           public static void UpdateAttributeValues(BlockReference blockreference, Dictionary<string, string> dictionary)
                     AttributeCollection attributeCollection = blockreference.AttributeCollection;
                     foreach (ObjectId attributeId in attributeCollection)
                         AttributeReference attributeReference = (AttributeReference)attributeId.GetObject(OpenMode.ForWrite);
                         if (dictionary.ContainsKey(attributeReference.Tag))
                             attributeReference.TextString = dictionary[attributeReference.Tag];
    Please use plain text.
    Re: Plot dwg with centered attributes - problem
    01-16-2012 01:04 PM in reply to: GVDB
    try the .AdjustAlignment option after adding an AttributeReference.
    From the object browser:
    Public Overridable Sub AdjustAlignment(alternateDatabaseToUse As Autodesk.AutoCAD.DatabaseServices.Database)
    Good luck, - alfred -
    Alfred NESWADBA
    01-16-2012 11:58 PM in reply to: GVDB
    Hi Alfred,
    thanks for your reply.
    I add -> newAttributeReference.AdjustAlignment(blockreference.BlockId.Database); to the code with no result.
    When I check the newAttributeReference.Justify in my code by defining them its "BaseCenter" which it has to be, so that's good.
    I discovered when I (in code)  insert the blocks with attributes and fill them and then I first save the drawing, with for example:
    Active .WorkingDatabase.SaveAs(@"K:\" + articleNumber + ".dwg", DwgVersion.AC1021);
    If I then plot the drawing it seems to be good.
    But I don't want/needs to save the drawing. I just want to open the drawing, insert some blocks, fill the attributes, plot it and then close the drawing.
    I must be something missing in saving / writing in a database of something, so the attributes doesn't have their right justification?????
    regards,
    Geert
    Valued Contributor
    SENL1362
    01-17-2012 02:43 AM in reply to: GVDB
    The same happended to me last week for centered text entities if the textstyle is changed via program.
    Both old and new text style used the same shx file and thus the text itself looks the same. But the location of the centered text changed. Redraw solved this issue for me and because it was a one time happening i didn't looked any further.
    So probably any update function need to be called after changing the attributes.
    Maybe any of the following may be helpful
        attRef.AdjustAlignment(db);
        blr.RecordGraphicsModified(true);
        doc.TransactionManager.QueueForGraphicsFlush();
        ed.Regen();
        Application.Update;
        Application.UpdateScreen();
        pvp.UpdateDisplay();
        db.UpdateExt(true);
    Moderator
    Alexander.Rivilis
    01-17-2012 03:04 AM in reply to: GVDB
    If attributes are MText attributes then use method AttributeReference.UpdateMTextAttribute
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    01-17-2012 07:07 AM in reply to: SENL1362
    Thanks for your reply!
    All your suggestions tried with no result, except ->  pvp.UpdateDisplay();
    I can't find a way to trigger this.
    What's pvp? and how do I get this?
    Geert
    Moderator
    Alexander.Rivilis
    01-17-2012 07:22 AM in reply to: GVDB
    As I remember for proper alignment you need temporary switch working database to database in which you add blockreference (and attributes):
    Database wdb = HostApplicationServices.WorkingDatabase;
    HostApplicationServices.WorkingDatabase = blockreference.BlockId.Database;
    ar.AdjustAlignment(blockreference.BlockId.Database);
    HostApplicationServices.WorkingDatabase = wdb;
    Valued Contributor
    SENL1362
    01-17-2012 12:17 PM in reply to: GVDB
    pvp is a Paperspace Viewport.
    Viewport pvp;
        DBDictionary layoutDic = trx.GetObject(db.LayoutDictionaryId, OpenMode.ForRead) as DBDictionary;
            foreach (DBDictionaryEntry entry in layoutDic)
                    Layout lay = trx.GetObject(entry.Value, OpenMode.ForRead) as Layout;
            if (!lay.ModelType)...
                    BlockTableRecord tbr = (BlockTableRecord)trx.GetObject(lay.BlockTableRecordId, OpenMode.ForRead);
            ObjectIdCollection vpIds = lay.GetViewports();
            Viewport pvp = tr.GetObject(vpIds[1], OpenMode.ForWrite) as Viewport;
    01-17-2012 11:39 PM in reply to: SENL1362
    Nope, this isn't the solution either.
    Also Alexander thanks for your reply but that's not working either.
    For now it leaves me nothing else then to SaveAs the drawing before I plot.
    It's a pity because that takes time.
    other suggestions?
    Geert
    Moderator
    Alexander.Rivilis
    01-18-2012 07:00 AM in reply to: GVDB
    Post resulting code after all modification.
