.NET
Active Contributor
galbori
Message 1 of 8 (572 Views)
Plot dwg througth vbnet exe
572 Views, 7 Replies
07-18-2012 12:56 AM
I would like to build an exe (using VS2008) to plot dwg without open Autocad
For each drawing I would like to read the dimension and based on this decide where to print the dwg (printer or plotter)
In your opinion it is possible?
Distinguished Contributor
VB_Autocad_guy
Message 2 of 8 (553 Views)
Re: Plot dwg througth vbnet exe
07-18-2012 08:55 AM in reply to: galbori
We'll ....
Yes you can create a program to Automate Autocad (and acomplish this task)
Autocad.exe will still be running (You can hide the program from View)
If you don't have Autocad installed on the local machine you'll need
And yes you could  create some logic to decide where to print the drawing.
But it sounds like one of two things:
1-  You are a CAD Adminstrator/Documentation Adminstrator and you need to Automate the printing of batches of design drawings. This options means programming is probably the way to go.
2- You have many different users who want to print batches of drawings from their own computer.
This option may be a problem if Autocad is NOT everyone's machine.
Sounds like you've got a bit more research ahead of you. :smileyhappy:
Active Contributor
galbori
Message 3 of 8 (549 Views)
07-18-2012 09:11 AM in reply to: VB_Autocad_guy
Thanks for your reply. I'm the cad administrator and I want to print list of drawings from our as400 for suppliers.
Now I use a dll loaded from autocad with "netload", it works but I don't like it because I've to launch Autocad and other problem. My target is load dwg, check the dimension and scale, then I know if I must send that dwg to plotter (A0,A1,A2,) or printer (A3,A4)
dgorsman
Message 4 of 8 (536 Views)
07-18-2012 11:28 AM in reply to: galbori
Whether you load a DLL, or automate AutoCAD through an external EXE, you can't get away from needing AutoCAD to open the DWG.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Active Contributor
galbori
Message 5 of 8 (534 Views)
07-18-2012 12:09 PM in reply to: galbori
I know, but is it possibile to use autocad in "background" ?
I would like to manage dwg (load, calculate dimension, scale and plotting it) using a background session of autocad
VB_Autocad_guy
Message 6 of 8 (532 Views)
07-18-2012 12:20 PM in reply to: galbori
Sure, you can use Autocad in the background.
Can you clarify... in the background of what?
Another session of Autocad... while working on other things on your computer?
How much experience do you have in .Net Programming or VBA programming for Autocad?
Active Contributor
galbori
Message 7 of 8 (521 Views)
07-18-2012 03:15 PM in reply to: VB_Autocad_guy
No, just one session. The pc will be dedicated.
I've a good experience in vb.net programming, but I' am almost a newby in vb.net for autocad
I don't like the dll with NETLOAD because if while autocad is processing dwg someone hit the keybord or  move the mouse, often send a command to autocad and blocked the procedure.
ADN Support Specialist
Balaji_Ram
Message 8 of 8 (497 Views)
07-21-2012 07:30 AM in reply to: galbori
Few more options to consider :
1) Accoreconsole.exe which is new in AutoCAD 2013 can be used to run script files on a set of drawings. You can also load and run commands from your custom plug-in from the script. Here is the link for more info on this option :
http://adndevblog.typepad.com/autocad/2012/04/getting-started-with-accoreconsole.html
2) Have you considered the ScriptPro tool ? It is a utility that can batch process a set of drawings and you can customize the things that you want to do on those drawings. Here is the link on this :
http://labs.autodesk.com/utilities/ADN_plugins/catalog/
Balaji
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Ask the Community
