.NET
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Plot Setting - Window Definition in model space has an offset
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
311 Views, 0 Replies
07-18-2005 12:34 PM
I have defined a "PlotSetting" that is associated with a "Model Space" layout.
oAcadTR = oAcadTM.StartTransaction
PSPlotSettings = CType(oAcadTR.GetObject(PSObjectID, OpenMode.ForWrite, False, False), PlotSettings)
Try
With oPSVal
.SetPlotConfigurationName(PSPlotSettings, "AutoCAD PostScript File Writer.pc3", MyBase.CananicalPaperSize)
.RefreshLists(PSPlotSettings)
.SetDefaultPlotConfig(PSPlotSettings)
.SetStdScale(PSPlotSettings, 1)
.SetUseStandardScale(PSPlotSettings, True)
.SetStdScaleType(PSPlotSettings, StdScaleType.StdScale1To1)
.SetPlotRotation(PSPlotSettings, PlotRotation.Degrees000)
Dim oWindow As New Autodesk.AutoCAD.DatabaseServices.Extents2d(myInsP oint.X, myInsPoint.Y, myInsPoint.X + MyBase.FormatWidth, myInsPoint.Y + MyBase.FormatHeight)
.SetPlotPaperUnits(PSPlotSettings, PlotPaperUnit.Inches)
.SetPlotWindowArea(PSPlotSettings, oWindow)
.SetPlotType(PSPlotSettings, Autodesk.AutoCAD.DatabaseServices.PlotType.Window)
Dim oCusScale As New Autodesk.AutoCAD.DatabaseServices.CustomScale(1.0, 1.0)
.SetCustomPrintScale(PSPlotSettings, oCusScale)
.SetPlotCentered(PSPlotSettings, True)
.SetZoomToPaperOnUpdate(PSPlotSettings, True)
.SetCanonicalMediaName(PSPlotSettings, MyBase.CananicalPaperSize)
.SetCurrentStyleSheet(PSPlotSettings, "monochrome.ctb")
End With
oAcadTR.Commit()
Catch ex As Exception
End Try
Here is the problem.
This works well when plotting in a layout. I get an "Offset" when plotting in model space.
The resulting Plotsetting window when plotting in Model Space has an offset. I have been unable to determine the source of the offset. I have been testing in an environment where there is only one UCS (world).
When I modify the PlotSetting manually, the .Net plotsetting (via debugger) object returns window values that have a "negative" of the offset when defined.
Have I ran into a bug?
Try
With oPSVal
End With
oAcadTR.Commit()
End Try
