.NET
Pick object or hit space bar
4 REPLIES 4
397 Views, 4 Replies
how to translate this to dot net?
yes it's using acad com api but the vba type api call won't work in dotnet
so i think the question is valid here
'vba version
Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As
Integer
Function checkkey(ByVal lngKey As Long) As Boolean
If GetAsyncKeyState(lngKey) Then
checkkey = True
Else
checkkey = False
End Function
how to do this in dotnet?
Sub SamplePickObjectOrSpace()
Dim eKeyCode As System.Windows.Forms.KeyEventArgs
'Public Const VK_SPACEBAR As KeyEventArgs = New eKeyCode.KeyCode.Space
Dim dimension As AcadDimension = Nothing
Dim sPrompt As String = "Pick Dimension"
Dim vp As New Object
Try
m_acadDoc.Utility.GetEntity(dimension, vp, sPrompt)
Catch ex As Exception
'what do i do with ekeyCode.Space here?
End Try
End Sub
Thanks for any help, and before you direct me to the vba group, i've already
asked there ...
I've been trying various things but nothings working yet
for example:
Try
If GetAsyncKeyState(eKeyCode.KeyCode.Space) Then
MsgBox("Hit space bar")
End Try
the error i get is
Access of shared member, constant member, enum member or nested type through
an instance; qualifying expression will not be evaluated.
mark
4 REPLIES 4
"mp" wrote in message
news:6307462@discussion.autodesk.com...
'vba version
Integer
checkkey = True
Else
checkkey = False
End Function
Try
End Try
End Sub
asked there ...
for example:
Try
End Try
the error i get is
mark
to show how eKeyCode was declared i include the following:
ps entire sample is:
Dim eKeyCode As KeyEventArgs
'tried eKeyCode = New KeyEventArgs but get other error
Try
End Try
End Sub
arcticad
Here you can filter out what you want to select and tell if the command is canceled.
{code}
Sub GetSomething()
Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor()
Dim sOptions As New PromptEntityOptions(vbCr & "Select Dimension: ")
sOptions.SetRejectMessage(vbLf & "Select Dimension: ")
sOptions.AddAllowedClass(GetType(Dimension), False)
Dim sRes As PromptEntityResult = Nothing
While (True)
sRes = ed.GetEntity(sOptions)
If sRes.Status *Less Than* *Greater Than* PromptStatus.OK Then
If sRes.Status.ToString = "Cancel" Then
MsgBox("Cancel")
Exit While
Else
Using db As Database = HostApplicationServices.WorkingDatabase()
Using tr As Transaction = db.TransactionManager.StartTransaction()
Dim myDWG As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Using lock As DocumentLock = myDWG.LockDocument
Dim myDim As Dimension = DirectCast(tr.GetObject(sRes.ObjectId, OpenMode.ForRead), Dimension)
MsgBox("You Picked " & TypeName(myDim))
End Using
End Using
End Using
End While
End Sub
{code}
(defun botsbuildbots() (botsbuildbots))
cool, thanks!
I'll see if that can live inside the existing vbnet project
I don't know if both com and net api code can be in same module...i'll find
out soon.
eventually i'd like to translate the whole thing over to c# anyway
so maybe this will serve as a first step
thanks
mark
wrote in message news:6308170@discussion.autodesk.com...
canceled.
{code}
Sub GetSomething()
Dim ed As Editor =
While (True)
MsgBox("Cancel")
Exit While
Else
End Using
End Using
End Using
End While
End Sub
{code}
arcticad
Your Welcome.
Convert to C#
http://www.developerfusion.com/tools/convert/vb-to-csharp/
also at the end of the transaction you should still commit the transaction even if it's read only.
tr.commit
End Using
commit is faster then dispose, I've been told.
”Boost
