I know the start point and angle, I want my user to pick the end point on the screen. I am using to jig to do it. I attach the code below. something like LENGTHEN command DYnamic option.
I draw the line, in the Jig.Sampler, I tried to use scale matrix transfer, but I did not get what I want. Is what I thought correct? Thank you if you can point me the right direction.
here is the code:
[code]
Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.GraphicsInterface
Imports Autodesk.AutoCAD.ApplicationServices
Public Class JigLine
Inherits DrawJig
#Region "private member fields"
Private gptIns As Point3d
Private pAngle As Double
Private cAngle As Double
Private _StartPoint As New Point3d(0, 0, 0)
Private _OldEndPoint As Point3d
Private _NewEndPoint As Point3d
Private _entityToDrag As Entity
Public Sub New()
End Sub
#End Region
#Region "property"
Public Property entityToDrag() As Entity
Get
Return _entityToDrag
End Get
Set(ByVal Value As Entity)
_entityToDrag = Value
End Set
End Property
Public Property Angle() As Double
Get
Return cAngle
End Get
Set(ByVal Value As Double)
cAngle = Value
End Set
End Property
Public Property Startpoint() As Point3d
Get
Return _StartPoint
End Get
Set(ByVal Value As Point3d)
_StartPoint = Value
End Set
End Property
#End Region
#Region "JigLine"
_
Public Function StartJig()
Dim EndPoint As Point3d
pAngle = Math.PI / 3.5
EndPoint = New Point3d(_StartPoint.X + Math.Cos(pAngle) * 10, _
_StartPoint.Y + Math.Sin(pAngle) * 10, 0)
_OldEndPoint = EndPoint
_entityToDrag = New Line(_StartPoint, EndPoint)
Application.DocumentManager.MdiActiveDocument.Editor.Drag(Me)
End Function
#End Region
#Region "Drag"
Public Function Drag()
If _entityToDrag Is Nothing Then
Throw New Exception("JigLine.Drag._entityToDrag")
End Function
#End Region
#Region "Sample"
Protected Overrides Function Sampler(ByVal prompts As JigPrompts) As SamplerStatus
Dim jigOpts As JigPromptOptions = New JigPromptOptions
jigOpts.Message = "\n Select End Point: "
jigOpts.BasePoint = _StartPoint
jigOpts.UseBasePoint = True
Dim rot As PromptPointResult = prompts.AcquirePoint(jigOpts)
If rot.Status = PromptStatus.None Then
Return SamplerStatus.OK
_NewEndPoint = rot.Value
If Not _NewEndPoint.Equals(_StartPoint) Then
If CursorHasMoved() Then
' rotate
Dim scale As Double = _StartPoint.DistanceTo(_NewEndPoint) / 10
entityToDrag.TransformBy(Matrix3d.Scaling(scale, _StartPoint))
_OldEndPoint = _NewEndPoint
Else
Return SamplerStatus.NoChange
End Function
#End Region
#Region "WorldDraw"
Protected Overrides Function WorldDraw(ByVal draw As WorldDraw) As Boolean
draw.Geometry.Draw(entityToDrag)
Return True
End Function
#End Region
#Region "CursorHasMoved "
Private Function CursorHasMoved() As Boolean
Dim myTolerance As Tolerance = New Tolerance(0.001, 0.01)
Return Not (_OldEndPoint.Equals(_NewEndPoint))
End Function
#End Region
End Class
[/code]
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
