.NET
Prajith76
Message 1 of 4 (607 Views)
Accepted Solution
Perpendicular Points on Polyline
607 Views, 3 Replies
07-19-2010 04:42 AM
Is there is any way to get perpendicular points on both sides of a polyline at a specified distance?
I tried to offset the polyline (PL) on both directions as (PL1 & PL2) but still confused how to get a perpendicular point on PL1 & PL2 with a given point on PL.
Your inputs will be much appreciated.
Prajith.
Distinguished Contributor
joshuamodglin
Message 2 of 4 (600 Views)
Re: Perpendicular Points on Polyline
07-19-2010 07:31 AM in reply to: Prajith76
Prajith,
Do a search for 'Polar' points in this Forum. This should provide you the answer you are looking for.
Josh Modglin
Advanced Technologies Solutions Logo
Valued Mentor
caddzone
Message 3 of 4 (592 Views)
07-19-2010 08:56 AM in reply to: Prajith76
You can use the GetFirstDerivative() method to get the direction
of the tangent vector at a given point on the polyline, which is
at a right angle with the perpendiuclar vector.
AcadXTabs for AutoCAD
Supporting AutoCAD 2000-2011
Prajith76
Message 4 of 4 (560 Views)
07-20-2010 02:07 AM in reply to: Prajith76
Hi Friends,
Goal achieved using the below function.
  Shared Function PolarPoint(ByVal BasePoint As Point3d, ByVal angle As Double, ByVal distance As Double) As Point3d
        Dim x As Double = distance * Sin(angle)
        Dim y As Double = distance * Cos(angle)
        Return New Point3d(BasePoint.X - x, BasePoint.Y + y, BasePoint.Z)
    End Function
Hi Tony,
I am not familiar with GetFirstDerivative() method. Certainly I will look at it how it goes.
Thanks a lot.
Prajith.
You are not logged in.
Announcements
Need installation help?
Ask the Community
