.NET
Periscope in .NET
15 REPLIES 15
Message 1 of 16
wesbird
642 Views, 15 Replies
Periscope in .NET
HI,
like in Periscope , can I create a tooltip when mouse hove over a AutoCAD object? if yes, how? is there any example? even in ObjectARX would help.
Thank you very much
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
15 REPLIES 15
Message 2 of 16
in reply to: wesbird
Hi Wes,
Interesting question, i could functionality for this as well. Did you ever
get an answer to your question, or created working code for it yourself? I'm
very excited if you do.
Henk
schreef in bericht news:5157541@discussion.autodesk.com...
HI,
Thank you very much
Wes
Message 3 of 16
wesbird
Check PointMonitor and PointMonitorEventArgs class in Managed Class Reference
Message 4 of 16
He, you're fast 🙂
Thanks, I will look at this
schreef in bericht news:5237197@discussion.autodesk.com...
Reference
Message 5 of 16
Is there an alternative class for AutoCAD 2005? Unfortunately, many of the event classes such as PointMonitor do not exist....
Message 6 of 16
There is a sample in the ARX skd to do it in C++
ObjectARX\samples\entity\MultilineTooltipSamp
wrote in message news:5237402@discussion.autodesk.com...
Message 7 of 16
Mikko
I saw a C# example somewhere but can't find it at the moment. Here is a VB example.
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Public Class Class1
Public Event PointMonitorEventHandler(ByVal WhatIsIt)
<CommandMethod("What")> _
Public Sub What()
AddHandler Application.DocumentManager.MdiActiveDocument.Editor.PointMonitor, New Autodesk.AutoCAD.EditorInput.PointMonitorEventHandler(AddressOf WhatIsIt)
End Sub
Private Sub WhatIsIt(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.EditorInput.PointMonitorEventArgs)
Dim ePaths() As FullSubentityPath = e.Context.GetPickedEntities()
If ePaths.Length > 0 Then
Dim ePath As FullSubentityPath = ePaths(0)
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim t As Transaction = db.TransactionManager.StartTransaction()
Try
Dim ent As Entity = CType(t.GetObject(ePath.GetObjectIds()(0), OpenMode.ForRead), Entity)
e.AppendToolTipText("I am an " + ent.GetType().ToString())
Finally
t.Dispose()
End Try
End Sub
End Class
Message 8 of 16
Same in c#. But he needs this for 2005 and as I understand native ARX is the
only
option.
wrote in message news:5244449@discussion.autodesk.com...
example.
Public Class Class1
Public Sub What()
AddHandler
End Sub
Try
Finally
t.Dispose()
End Try
End Sub
End Class
Message 9 of 16
>> understand native ARX is the only option.
The only option for tooltips ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
Message 10 of 16
I didn't think you could monitor the cursor in 05
with managed ARX? Or did I misunderstand what
he was looking for all together.
"Tony Tanzillo" wrote in message
news:5244644@discussion.autodesk.com...
Message 11 of 16
There are two seperate questions here... First, there was a question about the PointMonitor in general... I responded with a second question about implementing the PointMonitor in ACAD2005, since it seems like the upgrade will probably take a little while here.
On a side note (although somewhat related), the .NET wrapper for the pointmanager should be basically the same between 2005 and 2006... Is the wrapper open source or would it be possible to recompile only the PointMonitor portion for 2005?
Message 12 of 16
After looking at the 2005 managed API, yes you're
right.
"Paul Richardson" wrote in message news:5244663@discussion.autodesk.com...
Message 13 of 16
Paul's correct. There is no PointMonitor class in 2005's API.
No, you can't recompile it because there is no source
and it isn't nearly that simple (lot of dependence on
other APIs that are not in 2005 either).
I've said this before and I'll say it again. If you're serious
about .NET development, you need to upgrade to 2006.
Otherwise, you're not going to find much sympathy here
on how to get the benefits of the latter without ugrading.
wrote in message news:5244715@discussion.autodesk.com...
Message 14 of 16
Since I was using the info you gave me, technically you're correct...;)
news:5244714@discussion.autodesk.com...
right.
Message 15 of 16
At this juncture, with having done relatively little
work with the 2005 API, it's hard to remember what
is and is not there 🙂
"Paul Richardson" wrote in message news:5244764@discussion.autodesk.com...
right.
Message 16 of 16
Pointing you to this sample was meant to
highlight '
title="AcEdInputPointMonitor Class">AcEdInputPointMonitor'.
The
title="AcEdInputPointMonitor Class">tooltip part is just a
bonus.
size=2>
"Paul Richardson" <prichardsonATadelphia.net>
wrote in message
face=Arial size=2>news:5237453@discussion.autodesk.com
face=Arial size=2>...
C++
<smcclure>
wrote in message
face=Arial size=2>news:5237402@discussion.autodesk.com
exist....
”Boost
