.NET
*Gilles Plante
Message 1 of 7 (81 Views)
Path from VBA/VB 5 to VB 2005/.Net
81 Views, 6 Replies
03-02-2006 07:09 AM
Hi everyone,
I have done a lot of AutoCAD customization in VBA and VB 5, and now going to
VB 2005. I am still looking at VB 2005 and .Net in general, to find what is
the new "offer" and to determine which path I will follow to do the
transition. I came with these conclusions and would like to know if I am
right or wrong.
1. Using the Interop namespace, I can still use the old ActiveX (.COM)
interface I know so well, and benefit from the real OO language VB is now.
Advantages: I can come up to speed faster. Disadvantages: the .COM interface
may be removed, or may not updated in the future, forcing me to move to .Net
in some time.
2. Going straight to .Net. Advantages: access to a richer API.
Disadvantages: steeper learning curve.
Now a few questions
1. Using .Net for AutoCAD is in fact like using ObjectARX. Is this right ?
2. Using VBA, and to a certain point VB 5, the same code could be used with
more than one version of AutoCAD, for example 2002/2004/2005. Using .Net, is
the code tied to a single AutoCAD version ?
Gilles Plante
Distinguished Contributor
ChrisArps
Message 2 of 7 (81 Views)
Re: Path from VBA/VB 5 to VB 2005/.Net
03-02-2006 08:46 AM in reply to: *Gilles Plante
You can still use interop but it will be much slower than the dotnet interface. Each property or method must lock and unlock the document each time. The dotnet api with transactions is MUCH faster.
>>1. Using .Net for AutoCAD is in fact like using ObjectARX. Is >>this right ?
Dotnet is able to more directly wrap C++ objects versus ActiveX, so you get the power of ObjectARX without all the danger of C++.
>>2. Using VBA, and to a certain point VB 5, the same code >> Using .Net, is the code tied to a single AutoCAD version ?
If you stay away from COM, then you will not be tied to a specific version. Once com interop is used, you will have to generate a .dll for each Autocad release (yet another reason to get away from com).
Chris Arps
VisionREZ Team Lead
www.visionrez.com
*Gilles Plante
Message 3 of 7 (81 Views)
03-02-2006 01:58 PM in reply to: *Gilles Plante
Chris,
looks like there is something I misunderstand.
I thought that .Net was simply an indirect way of using ObjectARX (a wrapper
?). ObjectARX and .Net are different APIs that are developped separately,
and looks to be the prefered way to customize AutoCAD - at least it seems to
be the message from Autodesk - right ?
Gilles Plante
a écrit dans le message de news: 5100179@discussion.autodesk.com...
Chris Arps
VisionREZ Team Lead
www.visionrez.com
*Nemorarius
Message 4 of 7 (81 Views)
03-03-2006 12:38 AM in reply to: *Gilles Plante
Hello Gilles,
I'm currently using VS2005 Standard Edition and COM Interop. That is, I'm
translating automation servers I've written in Delphi and some lisp code as
well.
I've also been tinkering with the .NET api for a while.
As to the first: I've never worked more comfortably with COM before.
As to the second: the stuff is awfully underdocumented not to say
undocumented. The only companion you have seems to be the Visual Studio
object browser. Unless you have additional information (which I don't) you
're going to lose a lot of time just figuring out things. After a while, I
couldn't help feeling like some guinea pig.
I'm not quite unexperienced. I've been progragramming rather a lot since
1979.
Still, this is my own and personal opinion. May very well be I'm just too
plain stupid for the .NET api
Just play around with it for a while... The best way to find out.
Greetings.
ChrisArps
Message 5 of 7 (81 Views)
03-03-2006 05:32 AM in reply to: *Gilles Plante
ObjectARX is the native C++ interface, this is what AutoCAD is written in and you still must use to do some things.
For example, custom entities are not possible in dotnet, you must use C++.
Most of the dotnet api is done by exposing the C++ classes to dotnet with a managed wrapper class. This handles the memory managment and translation of the data from C++ to dotnet data types.
The nice thing about this technique is that it takes almost no effort on the part of the programmer versus an ActiveX interface that can take 40+hours to implement.
C++ / ObjectARX -> Does everything but is fast and dangerous (memory leaks, crashing pointers, etc).
Dotnet -> slower due to translation of data, but much safer and cost effective to program in.
I personally am 5 times more productive in dotnet than C++.
Chris Arps
*Gilles Plante
Message 6 of 7 (81 Views)
03-05-2006 03:46 PM in reply to: *Gilles Plante
Nemorarius,
I remember when I started programming AutoCAD R14 in VBA. The documentation
was also horrible. Coding simple things turned into a nightmare. Even today,
some of the examples in the AutoCAD documentation are buggy, or absent.
Internet came to the rescue, and books became available.
Regarding .Net, are there any good books helping programming AutoCAD using
.Net (I know, it is the $ 50,000 question...) ?
Gilles
Looks like
"Nemorarius" a écrit dans le message de news:
5100957@discussion.autodesk.com...
Hello Gilles,
well.
1979.
Greetings.
*Nemorarius
Message 7 of 7 (81 Views)
03-06-2006 06:44 AM in reply to: *Gilles Plante
Gilles,
As to the books on programming AutoCAD using the .NET api, I haven't seen
any.
Not in bookshops, that is.
I'm afraid the days when you could buy books on (serious) programming and
actually learn it in them are over.
A title such as "Programming AutoCAD using .Net" doesn't have much chance of
becoming a commercial succes.
So it's highly probable it will not materialize.
Greetings.
"Gilles Plante" wrote in message
news:5102199@discussion.autodesk.com...
Nemorarius,
Gilles
Looks like
Hello Gilles,
well.
1979.
Greetings.
You are not logged in.
Ask the Community
