Passing variables.
Passing variables.
SRSDS
Advisor Advisor
Passing variables.
SRSDS
Can someone suggest what is wrong here?
Diameter is passed in as 12.7 but it is not acceptint it as a true statement.
    Function Volume(Diameter As Single)
        If Diameter = 12.7 Then
        end if
    End Function
arcticad
    Function Volume(ByVal Diameter As Single) As Boolean
        If Diameter = CSng(12.7) Then
            Return True
        Else
            Return False
    End Function
(defun botsbuildbots() (botsbuildbots))
SRSDS
Thanks again!!
sbarlage
I think this will do it too:
If Diameter = 12.7# Then end if
_gile
Don't make VB more verbose than it is...
        Return Diameter = 12.7F
    End Function
 But why using a Single rather than a Double ?
Gilles Chanteau
GileCAD
GitHub
