.NET
Passing reference from C# to VB dll
4 REPLIES 4
536 Views, 4 Replies
Hi All,
I have written a Function in VB6.0 and made it as a dll. I have given this dll as a reference to a C# application. I have to pass an object to this VB dll as a parameter from C#. But i am getting error while passing the object. Here is the Coding
DemoProject.DemoClass DP = new DemoProject.DemoClass(); Autodesk.AutoCAD.Interop.Common.AcadObject Obj = e.DBObject;
DP.GetObjFromParent(ref Obj );
I am getting error at above line. Any help would be greatly appreciated. Thanks in advance.
Basha
4 REPLIES 4
What does the VB DLL function look like? What type is the argument of the
function? What is the error? It seems that the VB DLL function does not
recognise the type DBObject in Autodesk.AutoCAD.DatabaseServices namespace
(of course).
Assume the VB DLL function's argument is a AcadObject type, like
Public Function GetObjFromParent(obj As AcadObject) As ....
End Function
Then you should pass an AcadObject, not DBObject. Since DBObject and Entity
object in Autodesk.AutoCAD.Database Services namespace have a property
"AcadObject", which returns Acad COM object "AcadObject", you could try
this:
Autodesk.AutoCAD.Interop.Common.AcadObject Obj = e.DBObject.AcadObject;
wrote in message news:5408074@discussion.autodesk.com...
Hi All,
Thanks in advance.
Basha
Hi Norman,
My function in VB look like below
Public Function GetObjFromParent(Fname as String, Obj As AcadObject)
' My Stuff
End Function
My function in C#.Net look like this
public void objAppended(object o, ObjectEventArgs e)
DemoProject.DemoClass DP= new DemoProject.DemoClass();
string Fname = "E:\\New Demo\\Demo.xml";
DP.GetObjFromParent(ref Fname,ref Obj );
Error1: Cannot implicitly convert type 'object' to 'Autodesk.AutoCAD.Interop.Common.AcadObject'. An explicit conversion exists (are you missing a cast?).
Error2: No overload for method 'GetObjFromParent' takes '2' arguments
Hope this clearly explains my problem.
Basha
Sorry for the minor mistake in my previous reply:
DBObject's AcadObject property is actually returns an object of "object"
type, not "AcadObject" type, although the property is named AcadObject. So,
you need explicitly cast it as AcadObject before assigning it to an
AcadObject variable:
(Autodesk.AutoCAD.Interop.Common.AcadObject) e.DBObject.AcadObject;
As for Error2, in your original post, the VB function has only one argument,
have you re-written the VB DLL but forgotten to update the reference?
wrote in message news:5409039@discussion.autodesk.com...
Hi Norman,
' My Stuff
End Function
Basha
Hi Norman,
Thank you for your time. Actually i am passing two parameters, one is the string and the other is an object. In my original post i haven't specified the 1st argument. Now the first error was resolved but still i am getting the 2nd error.
Thanks in Advance,
Basha
”Boost
