.NET
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Parametric Dimensions
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hey Guys, am in Customization of AutoCAD and the problem am facing is with dimensions.
Am able to get normal dimensions but problem lies in Parametric Dimensions. Any Ideas on how to perform this Linear Constraint Dimension
Re: Parametric Dimensions
- Highlight
- Email to a Friend
Hi amitk_189,
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
Philippe Leefsma
Autodesk Developer Network
- Highlight
- Email to a Friend
In Parameter Tab we have Linear Dimensions, Aligned Dimensions.
Lets draw a Line and the dimension of this line is 15. Now if i change dimension to 25, the length of line should change to 25. Did you get it now?
And i found this solution you provided in link long time ago but did not succeed in it. I did lot of coding on it but was not able to get things in right order. If atleast one example would have been there it would be helpful.
- Highlight
- Email to a Friend
Philippe & Gopinath,
Just wanted to say thanks for the API in link above and is very useful.
amtik_189,
If I understand you correctly I accomplished what you described using the test commands in MgdConstraintAPITest
MGHLDIMALIGN - to add dimension
MGHLPARAM - to change the "expression" or length of line.
- Highlight
- Email to a Friend
Will try
- Highlight
- Email to a Friend
Nope its not working
