.NET
JamieVJohnson2
Message 1 of 9 (1,254 Views)
Parametric Constraints
1254 Views, 8 Replies
12-06-2010 11:23 AM
Hello everybody,
This may be a bit advanced, but I REALLY want to get programatic control over parametric constraints (acad 2011).  I have created a dynamic block with all these constraints, but now I want to create the block from near scratch all in code.  You see there will be some general common elements and then some random per project elements, that I need to set some simple constraints within the block.  (Coincident, Tangent, Aligned-dimension).
I have read the arx guide at Developer Guide / Advanced Topics / Associative Framework, and I actually understood most of it this time!  It would be REALLY nice if anybody had an example of how to use this system (managed or not, for I am a vb.net developer at first).  I have searched around and find nobody is programming to parametric constraints and telling about it.  Please help.
Thank you,
jvj
jvj
chiefbraincloud
Message 2 of 9 (1,233 Views)
Re: Parametric Constraints
12-07-2010 12:22 PM in reply to: JamieVJohnson2
Hi Jamie,
I am responding because no one else did.  I haven't had the time to get into Dynamic blocks yet.
That said, there is a post on Through The Interface which deals with accessing Dynamic properties, here:
http://through-the-interface.typepad.com/through_the_interface/2009/03/accessing-the-properties-of-a...
It was written using 2009 Acad, and Kean specifically replies to a Comment saying that there is (was) no API exposed for manipulating a Dynamic Block Definition, only references.  I took a quick look through my object browser in 2010, and I don't see anything there either, so unless this API is newly exposed in 2011, you may be out of luck.
I would suggest going to the TTIF post and leaving a comment for Kean, asking if this is still the case.
JamieVJohnson2
Message 3 of 9 (1,209 Views)
12-08-2010 07:19 AM in reply to: JamieVJohnson2
Hello chief, long time no read...
Yea some 2 years ago, I did a project with dynamic blocks and have a good handle on the concept.  Its the Parametric Constraints (Inventor's sketch constraints, such as a tangent constraint between a circle and a line), that came in with 2010, that I don't have an API for.  Several other guru's have complain about this as well, but has anybody figured something out?
jvj
jvj
Active Contributor LE3
Active Contributor
LE3
Message 4 of 9 (1,180 Views)
12-10-2010 07:51 AM in reply to: JamieVJohnson2
I do not have a job, so have a lot of time to play, with the api...
I have done some commands in ObjectARX with this... and have tried to port it into C#. Can't post the whole code, but to give an idea, attached it is an image of some portion of my code, and yes there is nothing open et-al that one can find, that you can use as a guide.
Just to fill my curiosity, any of you work as a programmer, doing AutoCAD based applications? using C++, ARX, MFC, Custom Objects, C#, etc? for a software or an architectural/engineering company ? - or - it is just a hobby.
Thanks!
JamieVJohnson2
Message 5 of 9 (1,168 Views)
12-10-2010 10:16 AM in reply to: JamieVJohnson2
As a CAD Manager (3 to 35 size CAD Staff(s)) I've been programming professionally (various languages and platforms) for 6 years, and 3 companies now.  ALL Learned the hard way (unless I get a good book)!  Once they find out what can be done, they begin to ask for very advanced tools.  I'll take a look at your code, and see what I can make of it.
jvj
jvj
JamieVJohnson2
Message 6 of 9 (1,162 Views)
12-10-2010 10:31 AM in reply to: JamieVJohnson2
Sweet!
This is wrapped in VB.Net and I can use the classes in vb!  One quick question tho, what is the purpose of "MyDict" string name of an NOD dictionary?  Is that a custom dictionary or is there a standard dictionary (already named) I need to find?
I'm all over this,  hopefully soon I'll be able to hand the community some functional tools.
jvj
jvj
Active Contributor
LE3
Message 7 of 9 (1,123 Views)
12-11-2010 10:14 AM in reply to: JamieVJohnson2
I frequent this site:
And just noticed, and appears there it is now a sample about it from a class at the AU2010 by Stephen Preston.
Creating Geometric and Dimensional Constraints Using the AutoCAD® .NET API
HTH.-
JamieVJohnson2
Message 8 of 9 (1,094 Views)
12-13-2010 10:15 AM in reply to: JamieVJohnson2
Now that hit the spot!  From Stephen's work I have a full belly of code examples, starter video and text to digest for weeks.  Like a loaded turkey dinner followed by a table full of deserts, with a honey cured ham dinner the next day, and a smoked BBQ dinner after that...  I will be re-arranging some of the code Stephen wrote to fit my design principals, but for any beginner there's loads of copy+paste goodies ready to use.  Thank you everybody!:robotvery-happy:
jvj
jvj
JamieVJohnson2
Message 9 of 9 (684 Views)
08-09-2011 02:27 PM in reply to: JamieVJohnson2
Hello Community,
Chew on this for a while.  Perhaps some new tools, ehancements, advanced CAD fun can come from it.  Not everything is here, but it is a nice head start.
jvj
jvj
You are not logged in.
Ask the Community
