.NET
Palette Size - Width Problem
1 REPLY 1
SRSDS
766 Views, 1 Reply
How do I control the width of a palette?
ps = New PaletteSet("MyPalette")
ps.Size = New System.Drawing.Size(164, 266)
ps.MinimumSize = New System.Drawing.Size(215, 150)
ps.TitleBarLocation = PaletteSetTitleBarLocation.Left
For some reason changing the Size and MinimumSize doesn't seem to have any impact.
Also..I've been basing a project on the width it allows me but on a lower resolution screen it loads cutting off the right hand segments of the controls.
1 REPLY 1
BlackBox_
in reply to: SRSDS
Not sure if you're using WPF, or Form Control, but in the Designer's Properties Pane, what are your MaxHeight, MaxWidth, MinHeight, and MinWidth Properties set to?
As I understand it, the PaletteSet.Size Property only controls the initial dimensions, and not necessarily the size after it's been modified by user (I could be wrong).
"How we think determines what we do, and what we do determines what we get."
”Boost
