I have a palette set with settings for a user to adjust with text & combo boxes an a button that launched a jig to insert a block with the properties the user selected. Everything works fine except for the two following problems, both I hope are in the attached code. Windows XP-SP2 x64 with ACAD2008.
1. Whenever the palette is docked and the user activates the jig, it automattically aborts the jig and returns to the palette.
2. Whenever the user has activated the palette during a session in drawing A and then opens drawing B, makes changes to drawing B, and returns to drawing A, there is a fatal error and AutoCAD crashes. It does not matter if the user closes drawing B or not. It does not matter if they save drawing B or not.
Thanks in advance for any help.
