.NET
Active Contributor
RichardCammeray
Message 1 of 9 (5,409 Views)
Overrule attributes(properties) for complex objects
5409 Views, 8 Replies
01-06-2013 09:10 PM
I am about to write the function using Overrule API to temporary override object’s colour to ByLayer for all entities in the drawing.
At this moment I just have simple class for testing (just to check if it is possible) and so far I can see problem with complex entities.
Entities such as Line, Polyline even BlockReferences work fine  but complex objects like HATCH, MTEXT and LEADER do not change colour as set in SetAttribute method.
Below is simple class I was testing.
public class ByLayerColorOverrule : DrawableOverrule
        public override bool WorldDraw(Autodesk.AutoCAD.GraphicsInterface.Drawable drawable, Autodesk.AutoCAD.GraphicsInterface.WorldDraw wd)
            base.WorldDraw(drawable, wd);
            return true;
        public override int SetAttributes(Drawable d, DrawableTraits t)
            int b = base.SetAttributes(d, t);
            if (d is Entity)
                // Set color to index 256 - By Layer
                t.Color = 256;
            return b ;
Any idea what I am doing wrong?
Thank you,
Richard
Hallex
Message 2 of 9 (5,396 Views)
Re: Overrule attributes(properties) for complex objects
01-06-2013 10:39 PM in reply to: RichardCammeray
Try to change your function this way:
            Autodesk.AutoCAD.DatabaseServices.Entity en = drawable as Autodesk.AutoCAD.DatabaseServices.Entity;
            if (en != null)
                short clr = 256;
                clr = wd.SubEntityTraits.Color;
                wd.SubEntityTraits.Color = 256;
                en.UpgradeOpen();
                en.ColorIndex = clr;
                if (en.HasPersistentReactor(en.ObjectId))
            ObjectIdCollection ids=    en.GetPersistentReactorIds();
            if (ids.Count > 0)
                foreach (ObjectId id in ids)
                    Entity obj = id.GetObject(OpenMode.ForWrite,false,false) as Entity;
                    obj.ColorIndex = clr;
                en.DowngradeOpen();
                wd.SubEntityTraits.Color = clr;
            return base.WorldDraw(drawable, wd);
            if (d is Entity)
                t.Color = 256;
            return b;
Active Contributor
RichardCammeray
Message 3 of 9 (5,363 Views)
01-07-2013 02:09 PM in reply to: Hallex
Hi Hallex,
Thank you for your suggestion, it works, but what I want is to change object’s colours just temporarily (in AutoCAD editor only)  that why I thought overrule is good tools to do that.
Code you suggested is actually changing colour of entities in file, that is exactly what I want to avoid.
Any other idea?
Thank you,
Richard
ADN Support Specialist
Balaji_Ram
Message 4 of 9 (5,317 Views)
01-15-2013 03:50 AM in reply to: RichardCammeray
Hello Richard,
I have come across a similar query which my colleague had asked to our engineering team.
It seems that the overrule does not change the color of some of the complex objects (leader. mtext for example) due to the way those entities are made up. The components of the complex entity may ignore the color set to the subentity traits while they get drawn.
As a workaround, it was suggested that a clone be created and its WorldDraw be called to draw to the screen.
Based on this suggestion, here is a sample code that I created to overrule the color of a leader / mtext :
public class MyDrawOverrule : DrawableOverrule
    Entity _clone = null;
	public override bool WorldDraw(Drawable drawable, WorldDraw wd)
        if ( (drawable is Leader || drawable is MText) && _clone != null)
            return _clone.WorldDraw(wd);
    public override int SetAttributes(Drawable drawable, DrawableTraits traits)
        if(drawable is Leader || drawable is MText)
            _clone = drawable.Clone() as Entity;
            _clone.SetAttributes(traits);
            _clone.ColorIndex = 2;
        return base.SetAttributes(drawable, traits);
public class Commands
	static MyDrawOverrule pldo = null;
	static List<ObjectId> entityIds = new List<ObjectId>();
	[CommandMethod("Test")]
	public void TestMethod()
		Document doc = Application.DocumentManager.MdiActiveDocument;
		Editor ed = doc.Editor;
        PromptEntityResult per = ed.GetEntity("\nSelect a Leader or MText");
		if (per.Status != PromptStatus.OK)
			return;
        entityIds.Add(per.ObjectId);
		if (pldo == null)
			pldo = new MyDrawOverrule();
            Overrule.AddOverrule(RXObject.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.Leader)), pldo, true);
            Overrule.AddOverrule(RXObject.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.MText)), pldo, true);
            pldo.SetIdFilter(entityIds.ToArray());
			Overrule.Overruling = true;
		else
		using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
			Entity reg = (Entity)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
			reg.RecordGraphicsModified(true);
			tr.TransactionManager.QueueForGraphicsFlush();
			tr.Commit();
Balaji
Developer Technical Services
Autodesk Developer Network
Active Contributor
RichardCammeray
Message 5 of 9 (5,286 Views)
01-17-2013 02:09 PM in reply to: Balaji_Ram
Hi Balaji,
Thank you for a example solving the issue.
It is actually simple but powerful way how to change any properties of entities, not just properties in DrawableTraits class.
Thank you,
Richard
Distinguished Contributor
quigs
Message 6 of 9 (5,269 Views)
01-18-2013 02:52 AM in reply to: Balaji_Ram
Hi there Balaaji,
Could this be the same reason why we are also having an issue with blocks that are in the worlddraw of an Object Overrule.  The colours of the blocks come in a darker.  As if they are being selected?
Ta,
Maritn.
My name is Martin.. :smileyvery-happy:
Balaji_Ram
Message 7 of 9 (5,263 Views)
01-18-2013 03:11 AM in reply to: quigs
Hello Martin,
I havent come across such issue with overrule.
I will try and reproduce the issue and update you in the other post.
http://forums.autodesk.com/t5/NET/Overuled-blocks-appear-darker/td-p/3750867
Balaji
quigs
Message 8 of 9 (5,260 Views)
01-18-2013 03:20 AM in reply to: Balaji_Ram
Thats great,
thank you so much :smileyvery-happy:.
quigs
Message 9 of 9 (5,237 Views)
01-23-2013 05:29 AM in reply to: Balaji_Ram
Hi there Balaji,
were you able to re-create the problem were having?
Maritn.
You are not logged in.
Ask the Community
