.NET
Moderator
Alexander.Rivilis
Message 11 of 18 (360 Views)
Re: Override default commands
04-05-2012 06:23 AM in reply to: annse
The reason is that, in fact, AutoCAD arx-application, that handles command _REFEDIT (ie AcRefEd.arx) is loaded when you first run the command and overrides your command REFEDIT. Therefore, need to load AcRefEd.arx before your's dll-file will be loaded:
Autodesk.AutoCAD.Runtime.SystemObjects.DynamicLinker.LoadModule ("AcRefEd.arx", false,true);
 Also you can modify registry to AcRefEd.arx will loaded with AutoCAD startup:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\RXX.X\ACAD-AYYY:ZZZ\Applications\AcadRefEdit
LOADCTRLS = 0x02 (instead of 0x0d)
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
annse
Message 12 of 18 (350 Views)
04-05-2012 07:49 AM in reply to: Alexander.Rivilis
I've modified the registry. Even if I undefine _REFEDIT, my definition doesn't get called.
Moderator
Alexander.Rivilis
Message 13 of 18 (335 Views)
04-06-2012 03:17 AM in reply to: annse
This code was tested with AutoCAD 2011-2013:
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
[assembly: ExtensionApplication(typeof(Rivilis.RefEditSubst))]
[assembly: CommandClass(typeof(Rivilis.RefEditSubst))]
namespace Rivilis
    public class RefEditSubst : IExtensionApplication
        void IExtensionApplication.Initialize()
            // Preloading AutoCAD RefEdit command arx-file
            SystemObjects.DynamicLinker.LoadModule("AcRefEd.arx", false, false);
        void IExtensionApplication.Terminate()
            // Do plug-in application clean up here
        //     Command group MUST be "ACAD_MAIN"
        [CommandMethod("ACAD_MAIN", "RefEdit", CommandFlags.UsePickSet)]
        public void RefEdit() // This method can have any name
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            ed.WriteMessage("MyRefEdit..");
            if (doc.Name.Contains("Test"))
                ed.WriteMessage("selected ref..");
            else
                doc.SendStringToExecute("_ACAD_REFEDIT.REFEDIT ", true, false, false);
Valued Mentor
KerryBrown
Message 14 of 18 (329 Views)
04-06-2012 04:37 AM in reply to: Alexander.Rivilis
Very nice solution Alexander !!
Regards
class keyThumper<T> : Lazy<T>;      another  Swamper
Moderator
Alexander.Rivilis
Message 15 of 18 (327 Views)
04-06-2012 04:41 AM in reply to: KerryBrown
Thanks! :smileyhappy:
annse
Message 16 of 18 (306 Views)
04-10-2012 01:02 AM in reply to: Alexander.Rivilis
Thank you, Alexander! Setting the command group did it.
Moderator
Alexander.Rivilis
Message 17 of 18 (304 Views)
04-10-2012 01:07 AM in reply to: annse
What about accept solution: http://forums.autodesk.com/t5/FAQ-How-To-Using-Autodesk/Accepted-Solutions/td-p/2701533 ?
annse
Message 18 of 18 (300 Views)
04-10-2012 01:12 AM in reply to: Alexander.Rivilis
Accepted. :smileyhappy:
Thanks again!
You are not logged in.
Announcements
Need installation help?
Ask the Community
