Override default commands
annse
Message 1 of 18
annse
Hi!
I'm trying to do something like this:
[Autodesk.AutoCAD.Runtime.CommandMethod("REFEDIT", Autodesk.AutoCAD.Runtime.CommandFlags.UsePickSet)]
public void RefEdit()
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
if (doc is a document I care about))
do my stuff...
else
run the default command...
I haven't undefined the default command, my definition of REFEDIT executes anyway.
I wanna be able to run the default command from my definition.
doc.SendStringToExecute(".REFEDIT ", true, false, false); will loop forever.
Replies (17)
Message 2 of 18
Balaji_Ram
I tried this which is very similar to what you are trying and it worked ok.
With this code, the line command is redefined only for drawings that have "Test" in their name.
Can you try this and see if it works for you ?
Maybe it will then help you identify the reason for your code to loop indefinitely.
// Add reference to Autodesk.AutoCAD.Interop
// Add reference to Autodesk.AutoCAD.Interop.Common
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
[CommandMethod("LINE")]
static public void LineMethod()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    if (doc.Name.Contains("Test"))
        ed.WriteMessage("My implementation of line");
    else
        AcadApplication app = (AcadApplication)Application.AcadApplication;
        app.ActiveDocument.SendCommand("_.LINE ");
void IExtensionApplication.Initialize()
    app.ActiveDocument.SendCommand("_.UNDEFINE _LINE ");
Balaji
Developer Technical Services
Autodesk Developer Network
Message 3 of 18
annse
Thank you for your quick response!
I've added required references and I now use SendCommand instead of SendStringToExecute.
This will still loop indefinitely. (If doc.Name doesn't contain "Test")
public void Initialize()
app.ActiveDocument.SendCommand("_.UNDEFINE _REFEDIT ");
static public void RefEdit()
ed.WriteMessage("New refedit...");
else
app.ActiveDocument.SendCommand("_.REFEDIT ");
Thanks again!
Message 4 of 18
Balaji_Ram
With the Line command the code does work.
But there seems to be some problem with using it for "Refedit".
Can you check if the command is actually undefined after sending the "undefine" command ?
Balaji
Message 5 of 18
Alexander.Rivilis
What about:
app.ActiveDocument.SendCommand("_ACAD_REFEDIT.REFEDIT ");
Command _REFEDIT defined in file AcRefEd.arx
If your's dll-file loaded after AcRefEd.arx - than no need to _UNDEFINE _REFEDIT, because your command REFEDIT override standard command REFEDIT. And standard command REFEDIT can be invoked using _ACAD_REFEDIT.REFEDIT
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 6 of 18
annse
Hi!
When I do the same thing with LINE instead of REFEDIT, my new definition of LINE won't run.
I get this error with both LINE and REFEDIT.
_.UNDEFINE
; error: no function definition: ACET-STR-REPLACE
_LINE
Thanks!
Message 7 of 18
annse
Thanks, Alexander! That works!
My dll is loaded in a .bundle installation.
So, because I can't override _LINE the same way, _LINE is loaded after my dll and _REFEDIT before?
Thanks again!
Message 8 of 18
annse
If the timing issue is irrelevant due to that the _REFEDIT command is already defined when my dll is loading,
I can use SendStringToExecute instead of SendCommand?
This way I won't have to echo the command.
Thanks again!
Message 9 of 18
Alexander.Rivilis
I think you can do it. Try!  🙂
Expert Elite Member
Message 10 of 18
annse
Hello again...
Sending "_ACAD_REFEDIT.REFEDIT " seems to redefine the command.
If the string is executed, the next time you run REFEDIT, it'll run the default definition.
[Autodesk.AutoCAD.Runtime.CommandMethod("REFEDIT", Autodesk.AutoCAD.Runtime.CommandFlags.Session & Autodesk.AutoCAD.Runtime.CommandFlags.UsePickSet)]
static public void RefEditDef()
ed.WriteMessage("selected ref..");
else
doc.SendStringToExecute("_ACAD_REFEDIT.REFEDIT ", true, false, false);
Any ideas?
Thanks!
Message 11 of 18
Alexander.Rivilis
The reason is that, in fact, AutoCAD arx-application, that handles command _REFEDIT (ie AcRefEd.arx) is loaded when you first run the command and overrides your command REFEDIT. Therefore, need to load AcRefEd.arx before your's dll-file will be loaded:
Autodesk.AutoCAD.Runtime.SystemObjects.DynamicLinker.LoadModule ("AcRefEd.arx", false,true);
 Also you can modify registry to AcRefEd.arx will loaded with AutoCAD startup:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\RXX.X\ACAD-AYYY:ZZZ\Applications\AcadRefEdit
LOADCTRLS = 0x02 (instead of 0x0d)
Expert Elite Member
Message 12 of 18
annse
I've modified the registry. Even if I undefine _REFEDIT, my definition doesn't get called.
Message 13 of 18
Alexander.Rivilis
This code was tested with AutoCAD 2011-2013:
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
[assembly: ExtensionApplication(typeof(Rivilis.RefEditSubst))]
[assembly: CommandClass(typeof(Rivilis.RefEditSubst))]
namespace Rivilis
    public class RefEditSubst : IExtensionApplication
            // Preloading AutoCAD RefEdit command arx-file
            SystemObjects.DynamicLinker.LoadModule("AcRefEd.arx", false, false);
        void IExtensionApplication.Terminate()
            // Do plug-in application clean up here
        //     Command group MUST be "ACAD_MAIN"
        [CommandMethod("ACAD_MAIN", "RefEdit", CommandFlags.UsePickSet)]
        public void RefEdit() // This method can have any name
            ed.WriteMessage("MyRefEdit..");
            else
Expert Elite Member
Message 14 of 18
kerry_w_brown
Very nice solution Alexander !!
Regards
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 15 of 18
Alexander.Rivilis
Thanks! Smiley Happy
Expert Elite Member
Message 16 of 18
annse
Thank you, Alexander! Setting the command group did it.
Message 17 of 18
Alexander.Rivilis
What about accept solution: http://forums.autodesk.com/t5/FAQ-How-To-Using-Autodesk/Accepted-Solutions/td-p/2701533 ?
Expert Elite Member
Message 18 of 18
annse
Accepted. 🙂
Thanks again!
