.NET
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Override default commands
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi!
I'm trying to do something like this:
[Autodesk.AutoCAD.Runtime.CommandMethod("REFEDIT", Autodesk.AutoCAD.Runtime.CommandFlags.UsePickSet)]
public void RefEdit()
Document doc = AcadApp.DocumentManager.MdiActiveDocument;
if (doc is a document I care about))
do my stuff...
else
run the default command...
I haven't undefined the default command, my definition of REFEDIT executes anyway.
I wanna be able to run the default command from my definition.
doc.SendStringToExecute(".REFEDIT ", true, false, false); will loop forever.
Re: Override default commands
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried this which is very similar to what you are trying and it worked ok.
With this code, the line command is redefined only for drawings that have "Test" in their name.
Can you try this and see if it works for you ?
Maybe it will then help you identify the reason for your code to loop indefinitely.
// Add reference to Autodesk.AutoCAD.Interop
// Add reference to Autodesk.AutoCAD.Interop.Common
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
[CommandMethod("LINE")]
static public void LineMethod()
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
if (doc.Name.Contains("Test"))
ed.WriteMessage("My implementation of line");
else
AcadApplication app = (AcadApplication)Application.AcadApplication;
app.ActiveDocument.SendCommand("_.LINE ");
void IExtensionApplication.Initialize()
app.ActiveDocument.SendCommand("_.UNDEFINE _LINE ");
Balaji
Developer Technical Services
Autodesk Developer Network
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your quick response!
I've added required references and I now use SendCommand instead of SendStringToExecute.
This will still loop indefinitely. (If doc.Name doesn't contain "Test")
public void Initialize()
app.ActiveDocument.SendCommand("_.UNDEFINE _REFEDIT ");
static public void RefEdit()
ed.WriteMessage("New refedit...");
else
app.ActiveDocument.SendCommand("_.REFEDIT ");
Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
With the Line command the code does work.
But there seems to be some problem with using it for "Refedit".
Can you check if the command is actually undefined after sending the "undefine" command ?
Balaji
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What about:
app.ActiveDocument.SendCommand("_ACAD_REFEDIT.REFE DIT ");
Command _REFEDIT defined in file AcRefEd.arx
If your's dll-file loaded after AcRefEd.arx - than no need to _UNDEFINE _REFEDIT, because your command REFEDIT override standard command REFEDIT. And standard command REFEDIT can be invoked using _ACAD_REFEDIT.REFEDIT
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi!
When I do the same thing with LINE instead of REFEDIT, my new definition of LINE won't run.
I get this error with both LINE and REFEDIT.
_.UNDEFINE
; error: no function definition: ACET-STR-REPLACE
_LINE
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks, Alexander! That works!
My dll is loaded in a .bundle installation.
So, because I can't override _LINE the same way, _LINE is loaded after my dll and _REFEDIT before?
Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If the timing issue is irrelevant due to that the _REFEDIT command is already defined when my dll is loading,
I can use SendStringToExecute instead of SendCommand?
This way I won't have to echo the command.
Thanks again!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello again...
Sending "_ACAD_REFEDIT.REFEDIT " seems to redefine the command.
If the string is executed, the next time you run REFEDIT, it'll run the default definition.
[Autodesk.AutoCAD.Runtime.CommandMethod("REFEDIT", Autodesk.AutoCAD.Runtime.CommandFlags.Session & Autodesk.AutoCAD.Runtime.CommandFlags.UsePickSet)]
static public void RefEditDef()
ed.WriteMessage("selected ref..");
else
doc.SendStringToExecute("_ACAD_REFEDIT.REFEDIT ", true, false, false);
Any ideas?
Thanks!
