• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Member
    Outputting a dxf file from an active drawing.
    168 Views, 1 Replies
    10-18-2012 02:52 PM
    I have several closed ployline shapes  in a particular layer, I need to know a way to:
    a) pick all the entites on that layer
    b) export to a dxf file each individual entity on the layer (yes, each entity saved to a separate dxf)
    Any help would be great. I am almost positive I can answer 'a' on my own using an object collection and a conditional statement? I am really more interested in how to export an entity from current open drawing to a dxf file in .net
    Please use plain text.
    Re: Outputting a dxf file from an active drawing.
    10-19-2012 03:22 PM in reply to: baw6718
    Try this code:
    using System.IO;
    using Autodesk.AutoCAD.ApplicationServices;
    using Autodesk.AutoCAD.DatabaseServices;
    using Autodesk.AutoCAD.EditorInput;
    using Autodesk.AutoCAD.Geometry;
    using Autodesk.AutoCAD.Runtime;
    [assembly: CommandClass(typeof(DxfOut.MyCommands))]
    namespace DxfOut
        public class MyCommands
            [CommandMethod("MyDxfOut")]
            public static void RunMyCommand()
                Document dwg = Application.DocumentManager.MdiActiveDocument;
                Editor ed = dwg.Editor;
                PromptSelectionResult res = ed.GetSelection();
                if (res.Status != PromptStatus.OK)
                    ed.WriteMessage("\n*Cancel*");
                    return;
                string folderPath = @"C:\Temp\ExportedFiles";
                try
                    ExportEntityToDxf(dwg.Database, res.Value.GetObjectIds(), folderPath);
                    ed.WriteMessage("\nSelected entities exported");
                catch (System.Exception ex)
                    ed.WriteMessage("\nError: {0}", ex.ToString());
                Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
            private static void ExportEntityToDxf(
                Database sourceDB, ObjectId[] entIds, string folderName)
                int i=0;
                foreach (ObjectId id in entIds)
                    i++;
                    string fileName =
                        folderName + "\\Test" + i + "_" + id.ObjectClass.DxfName + ".dxf";
                    if (File.Exists(fileName)) File.Delete(fileName);
                    using (Database db = new Database(true, true))
                        ObjectIdCollection ids = new ObjectIdCollection(new ObjectId[]{id});
                        sourceDB.Wblock(db, ids, Point3d.Origin, DuplicateRecordCloning.Ignore);
                        db.DxfOut(fileName, 16, DwgVersion.Current);
     I use AutoCAD2012. I started a drawing, drew a few entities (lines, circles...), placed them in different layers, colors. Then run the command "MyDxfOut". I ended up with a bunch of *.dxf files in C:\temp folder, which I opened in AutoCAD, and saw each Dxf file has a single entity with its layer/color being the same as the source entity.
    HTH.
