.NET
Opening objects ForRead but not closing them?
2 REPLIES 2
204 Views, 2 Replies
Dear All,
I'm a bit confused about what ObjectARX DevGuide
is suggesting and what happens in real life. It's about opening objects with
OpenMode.ForRead using TransactionManager - do I need to imlicitly Close()
opened object after I'm finished inspecting it, or it's performed somehow
automatically when current Transaction gets disposed? Here's what ObjectARX
DevGuide suggests:
Obtaining Pointers to Objects in a Transaction
If you use the getObject() function to obtain an
object pointer, you should never call close() on that
object pointer. Calling close() is valid only if you
obtained the pointer using acdbOpenObject() or the
object was newly created. For more information on when you can call
class=courier>close()
on an object pointer, see the following sections,
href="mk:@MSITStore:C:\Documents%20and%20Settings\Administrator\Desktop\docs\arxdev.chm::/arxdev188...
and
href="mk:@MSITStore:C:\Documents%20and%20Settings\Administrator\Desktop\docs\arxdev.chm::/arxdev181...
and also:
title="Mixing the Transaction Model with the Open and Close Mechanism ">Mixing
title="Mixing the Transaction Model with the Open and Close Mechanism ">The
transaction model coexists with the regular open and close mechanism described
in
href="mk:@MSITStore:C:\Documents%20and%20Settings\Administrator\Desktop\docs\arxdev.chm::/arxdev051...
chapter
5,
href="mk:@MSITStore:C:\Documents%20and%20Settings\Administrator\Desktop\docs\arxdev.chm::/arxdev05....
However, if you are using the transaction model, it is recommended
that you do not mix it with the open and close mechanism. For example, if you
obtained a pointer to an object using
class=courier>AcTransaction::getObject()
, you should
not call close() on
the object pointer, which could cause unexpected results and may crash AutoCAD.
However, you are free to open and close a particular object even if transactions
are active. You can also instantiate new objects, add them to the database, and
close them while transactions are active. The primary purpose of having the
mixed model is to allow simultaneous execution of multiple applications where
some use transaction management and others do not, but all of them are operating
on the same objects.
face=Verdana size=2>What really happens sometimes is that ACAD clugs and crashes
if I do not issue implicit Close() of an object. Here's a simple piece of code
utilizing above stated mechanism (sticking to DevGuide directives):
face="Courier New">Dim db
As Database =
Application.DocumentManager.MdiActiveDocument.Database()
face="Courier New">Dim trm
As
Autodesk.AutoCAD.DatabaseServices.TransactionManager =
db.TransactionManager
As Transaction =
trm.StartTransaction
face="Courier New">Dim bt
As BlockTable =
tr.GetObject(db.BlockTableId, OpenMode.ForRead)
face="Courier New" size=2>
face="Courier New" color=#0000ff size=2>Try
face="Courier New">   For
size=2>
Each ob
As ObjectId
color=#0000ff size=2>In
bt
face="Courier New">
Dim
btr As
size=2> BlockTableRecord = tr.GetObject(ob,
OpenMode.ForRead)
face="Courier New">
color=#0000ff>    If
UCase(btr.Name) = btr.ModelSpace
Then
color=#0000ff>
size=2>
color=#008080>'Inspect some ModelSpace properties...
size=2>
color=#0000ff>      End
color=#0000ff>If
color=#0000ff>
face="Courier New" size=2>Next
size=2>
color=#0000ff>Finally
face="Courier New" size=2>   bt.Dispose()
tr.Dispose()
face="Courier New" size=2>   trm.Dispose()
face="Courier New" color=#000000 size=2>
db.Dispose()
End Try
color=#0000ff>
face=Verdana>Thanks in advance for any suggestion or clarification.
face=Verdana>
face=Verdana>Regards,
face=Verdana>Maksim Sestic
2 REPLIES 2
Final conclusions... There is an error either in
.NET wrapper regarding TransactionManager behaviour, or in ObjectARX DevGuide.
Please note the statement from a full excerpt below:
"If you use the getObject() function to obtain
an object pointer, you should never call close() on
that object pointer."
What really happens is that ACAD crashes during
shutdown (Quit) if there is no Close() for obained object pointers
within Transaction. It's of no significance if object is opened ForRead or
ForWrite.
Maksim Sestic
that object pointer. Calling close() is valid only
if you obtained the pointer using acdbOpenObject()
or the object was newly created. For more information on when you can call
close() on an object pointer, see the following
sections,
href="mk:@MSITStore:C:\Documents%20and%20Settings\Administrator\Desktop\docs\arxdev.chm::/arxdev1...
and
Can you post some code that shows this behavior?
This shouldn't happen so I'm pretty sure there's something else going
on.
ALbert
in .NET wrapper regarding TransactionManager behaviour, or in ObjectARX
DevGuide. Please note the statement from a full excerpt below:
or ForWrite.
Maksim Sestic
obtain an object pointer, you should never call
on that object pointer. Calling
is valid only if you obtained the pointer using
acdbOpenObject() or the object was newly created.
For more information on when you can call close()
href="mk:@MSITStore:C:\Documents%20and%20Settings\Administrator\Desktop\docs\arxdev.chm::/arxde...
and
”Boost
