.NET
Opening/Adding Acad document - 2005 vs 2006?
4 REPLIES 4
273 Views, 4 Replies
Is there something I'm missing between 2005 and 2006? I've got a batch
processor that checks to see if an acad session is running and if so open a
document in that session and if its not running, open AutoCAD and then open
a document. The simple code works fine in AutoCAD 2005, but not with 2006.
This is my sub for detecting the acad session:
Imports Autodesk.AutoCAD.Interop.Common
Imports Autodesk.AutoCAD.Interop.AcadPlotClass
Sub DetectAcadSession()
blnAcadExist = False
' Check to see if Acad is open
On Error Resume Next
acad = GetObject(, "autocad.application") 'try to get the app object
If Err().Number <> 0 Then 'if not then create a new
one
acad = New AcadApplication
Else
blnAcadExist = True
Err().Clear()
ACADVer = acad.Version.ToString() 'save acad version for later
End Sub
This is the code I use to Open a document:
dwg = acad.Documents.Open(strDwgs(i), False) 'strDwgs(i) is valid
If I step through the code using AutoCAD 2006, it works. If I just run it,
I get "Call Rejected by Callee".
Any help or tips would be greatly appreciated!
4 REPLIES 4
temerson
Did you ever get any response to the issue you are experiencing. I'm having the exact same issue. I have also tested it in debug mode and it works but compiled mode it does not. The same code has worked for AutoCAD 2004 & 2005 but is broken in 2006. Thanks for any help you can give me...
temerson
I was able to get my code running by looping until autocad is idle then open the file. The following example is for VB 6.0
' GET AUTOCAD STATE. NOTE: AutoCAD.AcadState OBJECT
Set oState = oApp.GetAcadState
If Not oState Is Nothing Then
Do While oState.IsQuiescent = False
DoEvents
Loop
And here's what I used in .NET:
Dim AcState As AcadState
Dim blnAcState As Boolean = False
While blnAcState = False
AcState = acad.GetAcadState
If AcState.IsQuiescent Then
blnAcState = True
End While
Same solution, basically...
wrote in message news:4882190@discussion.autodesk.com...
DoEvents
Loop
Sometimes you just have to poke around a bit
to find the managed API equivalent:
Autodesk.AutoCAD.ApplicationServices.Application.IsQuiescent
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"pkirill" wrote in message news:4882466@discussion.autodesk.com...
blnAcState = True
End While
DoEvents
Loop
”Boost
