.NET
*T.Willey
Message 1 of 1 (58 Views)
Open drawing with a time limit
58 Views, 0 Replies
09-15-2006 08:55 AM
I have gotten all the help I can on the code side of things. It is running
now, but I need help on the Acad side of things now. The object is to open
a list of drawings (user selected) one at a time, issue the 3dorbit command,
let run for a certain amout of time (10 seconds right now), then close that
one, and open the next. I can get to the point of issueing the command, and
canceling it, but when it goes to close the current drawing, Acad crashes
out without any notice.
Any/all help is appreciated. I will attach a text file of the code also, as
this may not look good.
using System;
using System.Diagnostics;
using System.Timers;
using System.Windows.Forms;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.Runtime;
using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(Test.TimeLimitOpenv04))]
namespace Test
/// Description of TimeLimitOpen.
public class TimeLimitOpenv04
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl,
EntryPoint = "?acedPostCommand@@YAHPBD@Z")]
extern static public int acedPostCommand(string cmd);
private static string[] DwgList;//<---Modification
private static DocumentCollection DocMan = AcadApp.DocumentManager;
private static Document NewDoc;
private static int cnt = 1; //<---Modification
System.Timers.Timer CountDownTimer;
//- Constructor: sets up var's etc for this class before use.
public TimeLimitOpenv04()
CountDownTimer = new System.Timers.Timer();
CountDownTimer.Elapsed += new
ElapsedEventHandler(CancelCommand);
CountDownTimer.Interval = 10000;
~TimeLimitOpenv04() // <-- Destructor, do clean up here.
CountDownTimer.Elapsed -= new
public void CancelCommand(object sender, ElapsedEventArgs e)
acedPostCommand ("CancelCmd");
CountDownTimer.Enabled = false;
TimeLimitOpenv04.NewDoc.CloseAndDiscard();
TimeLimitOpenv04.NewDoc = TimeLimitOpenv04.DocMan.Open
(DwgList[cnt], true);
if (TimeLimitOpenv04.NewDoc !=
TimeLimitOpenv04.DocMan.MdiActiveDocument) {
TimeLimitOpenv04.DocMan.MdiActiveDocument =
TimeLimitOpenv04.NewDoc;
++TimeLimitOpenv04.cnt;//You access it by the class name
if (TimeLimitOpenv04.cnt > TimeLimitOpenv04.DwgList.Length) {
CountDownTimer.Dispose();
CountDownTimer.Enabled = true;
TimeLimitOpenv04.NewDoc.SendStringToExecute ("_.3dorbit", false,
false, true);
[CommandMethod("TestTimer4", CommandFlags.Session)]
public void Main()
Autodesk.AutoCAD.Windows.OpenFileDialog Dia =
new Autodesk.AutoCAD.Windows.OpenFileDialog(
"Select drawings to update Cloud layer", "", "dwg", "",
Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.AllowMultiple);
Dia.ShowDialog();
TimeLimitOpenv04.DwgList = Dia.GetFilenames();
if (TimeLimitOpenv04.DwgList.Length > 1)
(DwgList[0], true);
TimeLimitOpenv04.NewDoc.SendStringToExecute ("_.3dorbit\n",
false, false, true);
Tim
"A blind man lets nothing block his vision."
You are not logged in.
Ask the Community
