• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Re: Object do not display correctly on inactive drawing
    04-11-2012 03:38 PM in reply to: chiefbraincloud
    The code example contained within the AutoCAD NET Developers Guide does not provide
    for arbitrary pattern values.  It is simply a rudimentary code sample that reflects the means
    of adding a Hatch pattern to a drawing.  That is fine if that is what is needed.  For setting  the
    Hatch pattern to a variable set of values the hatch pattern code can be as follows:
    Dim acHatch As Hatch = New Hatch()
    'Add the hatch to the block table record and the transaction
    acBlkTblRec.AppendEntity(acHatch)
    acTrans.AddNewlyCreatedDBObject(acHatch, True)
    acHatch.SetDatabaseDefaults(acSpoolDb)
    ' Change from read to write mode
    acHatch.UpgradeOpen()
    'set the Hatch properties
    acHatch.Associative = True
    acHatch.PatternScale = 0.5
    acHatch.PatternAngle = Math.PI * 0.25
    acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31")
    ' Change from write to read mode
    acHatch.DowngradeOpen()
    'Attach to boundary loop
    acHatch.AppendLoop(HatchLoopTypes.[Default], acObjIdColl)
    ' Save the new hatch object to the database
    acTrans.Commit()
    For me the CommandFlag.Session flag was set in order for the hatch to display.
     If one has a better way of adding hatching that accepts differing parameters and displays correctly, then by all means share.  :smileyhappy:
    Please use plain text.
    chiefbraincloud
    04-11-2012 04:34 PM in reply to: hperison
    You sure about that?
    I'm getting confused now.  I was playing around with the example in the developers guide, and was just getting ready to post a comment here when you posted your last one.
    I was getting the hatch showing up with the right pattern angle, but the wrong scale, regardless of calling evaluate hatch or not.
    And even with the code you just posted, I am still getting an eInvalidInput Exception unless I move the PatternAngle setting to after calling SetHatchPattern.
    Now it is getting even wierder, because I have gone back to the original Developer guide code, added two lines to set the PatternAngle and PatternScale, and now it is working fine.  I have three separate functions each slightly different, and all three are working fine.
    If I take any of the three and move the PatternAngle setting to before the SetHatchPattern call, they all fail, eInvalidInput.
    04-12-2012 12:19 AM in reply to: chiefbraincloud
    Did you ever verify on what AutoCAD releases you are working? Because the order for PatternAngle before or after SetHatchPattern is depending on AutoCAD-release!
    I use this code working now from 2007 to 2012, not yet tested with 2013
    If ISHAcConn.AcadApp_VersionDouble < 18.1 Then
       Hatch.PatternAngle = (RotationDegree / 180 * Math.PI)
    End If
    Hatch.SetHatchPattern(DatabaseServices.HatchPatternType.PreDefined, tPatternName) If ISHAcConn.AcadApp_VersionDouble >= 18.1 Then Hatch.PatternAngle = (RotationDegree / 180 * Math.PI) End If
    BTW: I'm really surprised that the hatch-creation is working without the .EvaluateHatch
    - alfred -
    Alfred NESWADBA
    04-12-2012 07:49 AM in reply to: alfred.neswadba
    Due to my excitement in getting this to finally work I made an error in my latest code.
    UpgradeOpen and DowngradeOpen lines are not required and do nothing.  I have subsequently
    removed those lines and the code still works as desired.
    During my attempts to remedy the problem, I had a suspicion that sequence order was important
    and was moving the order around without much success in getting the correct sequence.  Upon review
    of my original post, I see where I have gone astray.
    I am using a AutoCAD 2010 - 64bit platform with VS2010 Pro
    Thank you Alfred, as I am glad to know that I am going to need to implement a caveat for later versions of Autocad.
    I think this can be put to rest now:smileyhappy:
