• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Object do not display correctly on inactive drawing
    307 Views, 13 Replies
    04-10-2012 03:51 PM
    I have created a NET routine which, when executed, creates a schematic drawing representation of the parent (active drawing).  All of the procedures execute as they should, however one is a mystery.    HATCH
    On the schematic (inactive document) the hatch appears with the Autocad default settings for the pattern used. The properties that I am looking at are:   The pattern scale and the hatch angle.
    The new hatch pattern is displayed with a pattern scale of 1.0  and a hatch angle of 0.0    when they should be displayed with a pattern scale of 0.5 and a hatch angle of 45
    Upon reviewing the hatch properties, by double clicking on the offending hatch pattern, I find that the values are are correct and as expected  (0.5 and 45).     By closing the hatch property dialog, the hatch pattern updates itself.
    Why doesn't this occur automatically, even linetypes do not appear correctly until a regen is manually involked?
    Is it because the hatch pattern or other elements are not being drawn on the active document?
    Is this just Autocad?
    I have attempted to do the same test via COM  and the results are the same.
    I have relentlessly searched for documentation on this occurance whithout much success and
    I can't believe that no one programically creates supporting documents from a parent drawing.
    Below is some code:
    ' Create the hatch object and append it to the block table record
    Dim acHatch As Hatch = New Hatch()
    ' Set the properties of the hatch object
    acHatch.SetHatchPattern(HatchPatternType.PreDefined, "ANSI31")
    acHatch.PatternScale = 0.5
    acHatch.PatternAngle = Math.PI * 0.25
    ' Add the hatch object to the new database.  If these 3 lines of code
    ' are before the pattern settings an "eAmbiguousObject" error will
    ' occur when the hatch object is evaluated.
    acHatch.SetDatabaseDefaults(acNewDb)
    acBlkTblRec.AppendEntity(acHatch)
    acTrans.AddNewlyCreatedDBObject(acHatch, True)
    ' Define the host working database.  If this is not added here the
    ' hatch does not appear until the document is saved and reopened
    HostApplicationServices.WorkingDatabase = acHatch.Database
    acHatch.Associative = True
    acHatch.AppendLoop(HatchLoopTypes.[Default], acObjIdColl)
    acHatch.EvaluateHatch(True)
    ' Save the new object to the database
    acTrans.Commit()
    Please use plain text.
    Re: Object do not display correctly on inactive drawing
    04-11-2012 12:27 AM in reply to: hperison
    just one idea (haven't tried your code): what happens, if you do the .AppenLoop and .EvaluateHatch before you add the hatch-object to the blocktablerecord and to the transaction?
    - alfred -
    Alfred NESWADBA
    chiefbraincloud
    04-11-2012 10:07 AM in reply to: alfred.neswadba
    I had to look at my own code to verify this, but what will happen (if you .AppendLoop before adding the hatch to the database) is you will get an eNotInDatabase exception.
    The order of his set properties, then add to the database, then make associative and append loop is the same order as my code.  I don't experience the same problems he does, but my code works with the active document.
    So, my question to the OP is, you say it is an inactive drawing, but does that mean the document is open in the editor, and not active, or is it a side database that is not open in the editor?
    Either way you could try calling acHatch.Database.TransactionManager.QueueForGraphicsFlush()
    If it is open in the editor, you could try calling Editor.Regen (once at the end of your code).
    There is also a RecordGraphicsModified(bool) method, but according to the SDK help files the default is True, which is supposed to Update the entity when it is closed.
    On a different note, you might have this somewhere else but it is not in the code you have shown, make sure that you reset the WorkingDatabase back to the original Database.
    04-11-2012 10:34 AM in reply to: alfred.neswadba
    My code sample is almost the same as that of the AutoCad documentation.  However, unlike the documentation, if I do not define the Hatch Pattern Type before appending to the BlockTable record I encounter an eAmbiguousOutput error.    With this in mind it does not matter to much where I set the PatternScale and Pattern Angle values.  I just opted to keep the m all together for simplicity.
    Unlike the documentation, I had already previously defined the hatch boundary, so all that was necessary was to supply the ObjectID Collection.  I have also had to specify what database default to implement as well as establish the working database.
    If you examine your idea, it won't work because according to the Autocad documentation:
         "When you have finished defining the hatch it must be evaluated before it can be displayed.
          Use the EvaluateHatch method to do this."
    Therefore, the Hatch object must be fully defined before the evaluation can be performed.  If one does as you have suggested an eNotInDatabase error will be encountered.
    It appears that in order for the required changes to be displayed in a non-active document, which is open in the editor, the non-active document must be made the 'current' document when the changes occur. The API that does that is not exposed to managed code, and it can't be P/Invoked either.  To make the non-active document the 'current' document causes the main execution to be halted until the parent document becomes active again.  This is not the desired effect that I am looking for.
    It appears that I may have to create a custom hatch pattern to achieve the desired results that I am looking for instead of using the Autocad available Hatch patterns.
    04-11-2012 10:45 AM in reply to: chiefbraincloud
    To answer your question chief,
        "So, my question to the OP is, you say it is an inactive drawing, but does that mean the document is open in the
         editor, and not active, or is it a side database that is not open in the editor?"
     The inactive drawing is one that is open in the editor but does not have the focus.  It is being programically populated by elements extracted from the active drawing where the code has be executed from.
    In other words:  Active Drawing = MDIDocument(0)
                            InactiveDrawing = MDIDocument(1)
        "If it is open in the editor, you could try calling Editor.Regen (once at the end of your code)."
    I have attempted this, without any success as the hatch pattern must be opened from the properties manager and the values accepted as displayed in order for the hatch to display as expected.
    I am going to test some of the other suggestions that you have provided.
    04-11-2012 11:37 AM in reply to: chiefbraincloud
    Chief, you wrote:
         "Either way you could try calling acHatch.Database.TransactionManager.QueueForGraphi​csFlush()"
    - Exception   eNotOfThisDatabase      Doesn't matter how I do this or where, I get the same exception result
         "There is also a RecordGraphicsModified(bool) method, but according to the SDK help files the default is True,
          which is supposed to Update the entity when it is closed."
    - I agree and this shouldn't be an issue
         "On a different note, you might have this somewhere else but it is not in the code you have shown, make sure
         that you reset the WorkingDatabase back to the original Database."
    - Yes, this was taken care of
    Thanks - No worries, This is just an annoyance rather then anything else.   I think that I will simply create my own custom hatch pattern or hatch function to suit my needs.
    chiefbraincloud
    04-11-2012 12:39 PM in reply to: hperison
    oddly enough, I have a couple of hatch functions (one generic, and one very specific) and neither of them call .EvaluateHatch, but both functions work fine.
    obviously that is irrelevant though.
    You can however activate the second document using managed code.  Your comment regarding this leads me to believe that you do not have the CommandFlag.Session set?
    You need that, then you should just be able to set the DocumentCollection.MdiActiveDocument = MyDoc
    First, I was not confident that it would solve the problem, but still, the exception is wierd, since the way I wrote it there specifically obtains the TransactionManager from the Database that the acHatch is in, so how could it be NotOfThisDatabase? :smileytongue:
    04-11-2012 01:17 PM in reply to: chiefbraincloud
    Isn't that interesting.  I commented out the .EvaluateHatch and found that the code worked fine too.
    I guess that goes to show that even the net samples have some flaws or residual elements from earlier days.
    By removal of this code I am not restricted as to the line location of my property values placement.
    CommandFlag.Session set?   Not anymore, I did have at one point.  I will rest this and try again.
    Lastly,  eNotOfThisDatabase    -  Has me baffled too
    I am keeping my code for futher evaluation.   Sometimes I am like a dog with a bone in these matters.:smileytongue:
    chiefbraincloud
    04-11-2012 01:59 PM in reply to: hperison
    FYI, You do still have to SetHatchPattern before setting PatternAngle.
    As far as the Session flag, if you can get away without it, you should.  I only mentioned it since it seemed like the only way to make the code work right was going to be activating the other document, in which case you would need the Session flag, but if you can get the code to work without activating the document, then do that and skip the session flag.
    In my opinion, "like a dog with a bone" is the way to be :smileywink: Just accepting it and moving on doesn't really teach you anything.  So I tend to be like a Pit Bull with a bone and sink my teeth in and don't let go until I understand why.
    04-11-2012 02:47 PM in reply to: chiefbraincloud
    This is the first time I have ever needed to do any hatching in NET and felt that I had nothing wrong with what I was originally doing.   Consequently, I have gone back to square 1 and decided to actually evaluate the Hatch example contained within the AutoCad NET Developers guide.
    LOL  it does exactly the same thing as my code.  I have to double-click on the hatch pattern drawn within the active drawing and accept the current values before the hatch pattern will change.
    So obviously I have missed something here that was not hinted at in the Developers Guide and need to do some further investigation.   I am going to have to get the initial code correct before proceding any further.
    I will post the correct coding procedure when I am finished so others will not go down this same road.
     Thanks for your help
