• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    RamanSBV
    Not able to given Specify insertion point
    93 Views, 1 Replies
    03-20-2012 04:43 AM
    I have issue with sendstringtoexecute method for imageattach.
                    Document doc = (Document)ActiveDocument;
                    string filelocation = Regex.Replace(imagePath, "\\\\""\\\\");
                    doc.SendStringToExecute("(Command \"imageattach\" \"" + filelocation + "\")" + Environment.NewLine, truefalsetrue);
    it is opening image attach and after that i am not able to position it.  by default it is taking 0,0 as x and y
    Please help me..
    Thanks in advance...
    Please use plain text.
    ADN Support Specialist
    Re: Not able to given Specify insertion point
    03-20-2012 06:24 PM in reply to: RamanSBV
    Hi there,
    You could use the command line version of IMAGE command instead, i.e. -IMAGE:
    (command "_-IMAGE" "_ATTACH" "C:\\test.bmp" "0,0" "1" "0")
    In the above I set insertion point to [0,0] but you could change that to anything else.
    I hope this helps.
    Adam Nagy
    Autodesk Developer Network
    Adam Nagy
    Developer Technical Services
