.NET
Valued Contributor
RamanSBV
Message 1 of 2 (125 Views)
Not able to given Specify insertion point
125 Views, 1 Replies
03-20-2012 04:43 AM
I have issue with sendstringtoexecute method for imageattach.
                Document doc = (Document)ActiveDocument;
                string filelocation = Regex.Replace(imagePath, "\\\\""\\\\");
                doc.SendStringToExecute("(Command \"imageattach\" \"" + filelocation + "\")" + Environment.NewLine, truefalsetrue);
it is opening image attach and after that i am not able to position it.  by default it is taking 0,0 as x and y
Please help me..
Thanks in advance...
ADN Support Specialist
adam.nagy
Message 2 of 2 (98 Views)
Re: Not able to given Specify insertion point
03-20-2012 06:24 PM in reply to: RamanSBV
Hi there,
You could use the command line version of IMAGE command instead, i.e. -IMAGE:
(command "_-IMAGE" "_ATTACH" "C:\\test.bmp" "0,0" "1" "0")
In the above I set insertion point to [0,0] but you could change that to anything else.
I hope this helps.
Adam Nagy
Autodesk Developer Network
Adam Nagy
Developer Technical Services
You are not logged in.
Ask the Community
