Not able to given Specify insertion point
I have issue with sendstringtoexecute method for imageattach.
                Document doc = (Document)ActiveDocument;
                string filelocation = Regex.Replace(imagePath, "\\\\""\\\\");
                doc.SendStringToExecute("(Command \"imageattach\" \"" + filelocation + "\")" + Environment.NewLine, truefalsetrue);
it is opening image attach and after that i am not able to position it.  by default it is taking 0,0 as x and y
Please help me..
Thanks in advance...
adam.nagy
Autodesk Support
Autodesk Support
Hi there,
You could use the command line version of IMAGE command instead, i.e. -IMAGE:
(command "_-IMAGE" "_ATTACH" "C:\\test.bmp" "0,0" "1" "0")
In the above I set insertion point to [0,0] but you could change that to anything else.
I hope this helps.
Adam Nagy
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
