.NET
No 'SelectionSets' in VB.net
11 REPLIES 11
Message 1 of 12
NirantarVidyarthee
1704 Views, 11 Replies
From the AutoDESK help docs (http://docs.autodesk.com/ACD/2013/EN...ber=d30e719293)
"AutoCAD.Application.ActiveDocument.SelectionSets. Add method
Not needed/provided" in VB.Net
Thus 'Autodesk.AutoCAD.ApplicationServices.Application. DocumentManager.MdiActiveDocument.SelectionSets' will not work.
So, I can't store multiple selection sets in VB.Net?
Why is it not provided? Or is there some other way to do that?
11 REPLIES 11
Message 2 of 12
It seems you do not know the difference of programming language (VB.NET/C#...) and AutoCAD APIs (COM API/.NET API).
AutoCAD.Application.ActiveDocument.SelectionSets. Add() still exists in COM API and can be used when needed. With AutoCAD .NET programming (VB.NET/C#), AutoCAD .NET API usually provides enough functionlities, but you can easily mix COM API calls in it (in many cases it is not necesary, as you quoted!).
So, what do you do that you have to use "AutoCAD.Application.ActiveDocument.SelectionSets. Add()", instead of various selecting methods provided in .NET API?
Norman Yuan
Drive CAD With Code
Message 3 of 12
Hallex
in reply to: NirantarVidyarthee
SelectionSet object is member of
Autodesk.AutoCAD.EditorInput namespace
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 4 of 12
Obviusly, I don't know the difference between VB and VBA. That;s the reason I came here and asked the question.
But my original quesry remains: How can I access the SelectionSets collection (or its equivalent) in VB.Net.
If I create 2 selection sets ss1 and ss2, then how do I access one of these like:
ThisDrawing.SelectionSets("SS1")
Message 5 of 12
Hallex
Show your Sub code to see what you started wth,
guess you want to use Interop library?
Message 6 of 12
NirantarVidyarthee
in reply to: Hallex
"If I create 2 selection sets ss1 and ss2, then how do I access one of these like:
Message 7 of 12
Hallex
I didn't see your code, well, then try my attempt
    <CommandMethod("testAcadSelections")> _
    Public Shared Sub testSelections()
        '' borrowed from Luis Esquivel
        Dim AcadComApp As AcadApplication = Nothing
        Dim progId As String = "AutoCAD.Application.18" ''   <-- AutoCAD 2010
        Try
            ' Get a current instance of AutoCAD
            AcadComApp = TryCast(GetObject(, progId), AcadApplication)
        Catch ex As System.Exception
            Try
                ' Create a new instance of AutoCAD
                AcadComApp = TryCast(CreateObject(progId), AcadApplication)
            Catch exx As Exception
                MsgBox(exx.Message)
                Exit Sub
            End Try
        End Try
        Try
            ' Get the active document
            Dim AcadComDoc As AcadDocument = TryCast(AcadComApp.ActiveDocument, AcadDocument)
            ' Get AcadSelectionSets collection
            Dim AcadSets As AcadSelectionSets = TryCast(AcadComDoc.SelectionSets, AcadSelectionSets)
            ' Declare AcadSelectionSet
            Dim AcadSsetObj As AcadSelectionSet = Nothing
            ' Get a StringBuilder object
            Dim sb As StringBuilder = New StringBuilder
            ' Add some selections to document
            For i As Integer = 0 To 24
                Dim setName As String = "Selection" & (i + 1).ToString()
                AcadSsetObj = AcadSets.Add(setName)
                sb.AppendLine(AcadSsetObj.Name)
            Next
            MsgBox("Number of selections created: " & AcadSets.Count.ToString() & vbLf & sb.ToString())
            Dim layoutName As String = AcadComDoc.GetVariable("ctab").ToString()
            ' Get the very first selection
            AcadSsetObj = AcadSets.Item(0)
            ' Create filter to select attributed blocks on current layout
            Dim filterType(2) As Short
            filterType(0) = 0
            filterType(1) = 66
            filterType(2) = 410
            Dim filterData(2) As Object
            filterData(0) = "insert"
            filterData(1) = 1
            filterData(2) = layoutName
            ' Perform the Select method
            AcadSsetObj.Select(AcSelect.acSelectionSetAll, , , filterType, filterData)
            ' Display result
            MsgBox("First selection:" & vbLf & "Number of block selected: " & AcadSsetObj.Count.ToString())
        Catch aex As System.Exception
            MsgBox(aex.Message & vbLf & aex.StackTrace)
        Finally
            ' AcadComApp.Quit()
            AcadComApp = Nothing
        End Try
    End Sub
 See for more
http://through-the-interface.typepad.com/through_the_interface/2010/02/handling-com-calls-rejected-b...
Message 8 of 12
NirantarVidyarthee
in reply to: Hallex
Thankyou but my question is not about how we can use COM API for getting SelectionSets collection. My question is why .NET API does not provide this and is there any other way in .NET API, other than probably creating my own collection.
Message 9 of 12
Hallex
My answer is in post#3 if you don't understand it
Type:
in editor console,
then highlight it and select from right clicking mouse: Go to Definition,
then scroll down to see Selection within object Browser
You can see so there is no SelectionSets collection in there
just only SelectionSet object only, and also read the docs for more
Message 10 of 12
NirantarVidyarthee
in reply to: Hallex
" You can see so there is no SelectionSets collection in there
just only SelectionSet object only, and also read the docs for more."
I know this.And I stated this in my first post.
I am asking why? What could be the logical reason behind not having the collection? And is using COM API the only alternative?
Message 11 of 12
Hallex
Simply use List (Of Selectionset) but you did not extend
the number of SelectionSet more than 255
Message 12 of 12
There is no need for a collection of SelectionSet in the .NET.  API.
SelectionSets are things you get friom calling editor methods to select objects, and after you get them and do what you need with the objects they contain, you discard them.
Unlike ActiveX SelectionSets, managed SelectionSets are not re-usable. There is no Clear() method to empty them and there is no way to re-use them. Unlike ActiveX selection sets, managed selection sets do not have methods to select objects.The Editor class has those methods, and they return a new managed SelectionSet each time you call them, so there's really no point or purpose to having a collection of managed SelectionSets.
The ActiveX and managed APIs are not remotely similar, and I think that's the underlying problem here. You can't approach programming with the .NET API as if it were just a managed equivalent of the ActiveX API, because it is not. It is very different and more difficult to use, but more powerful at the same time.
”Boost
