.NET
Active Contributor
Fredrik.Larsen
Message 1 of 5 (175 Views)
Next object in scan
175 Views, 4 Replies
01-09-2013 12:26 AM
Is there a way to get the next object in the dwg file when I know the object id of an object?
foreach(ObjectId oid in blockTableRecord)
    // Check next object(using next oid)
    // Do something using oid
Alfred.NESWADBA
Message 2 of 5 (170 Views)
Re: Next object in scan
01-09-2013 12:49 AM in reply to: Fredrik.Larsen
why not modifying your loop in that way:
   declare previousObj
   declare currentObj
       // if previousObj defined (so to step over if it's the first object in queue and continue with loop2/object2)
             // get currentObj
             // check currentObj
             // do something with previousObj
             // save currentObj as previouObj for the next loop
Another option might be to first scan through the BlockTableRecord and gather the ObjectIDs into a collection (or any type of list/array that can be accessed by an index).
- alfred -
Alfred NESWADBA
Active Contributor
Fredrik.Larsen
Message 3 of 5 (151 Views)
01-09-2013 04:31 AM in reply to: Alfred.NESWADBA
Yeah, i figured I posted a bad example. Your solution is ok when it comes to going through all objects.
But what I actually wanted was to know if it was possible to find the next element just from an object id without scanning the entire file or storing all the ids?
Moderator
Alexander.Rivilis
Message 4 of 5 (146 Views)
01-09-2013 05:06 AM in reply to: Fredrik.Larsen
What do you mean by the next object?
1. This could be the next ObjectId of entities within BlockTableRecord
2. This can be ObjectId with Handle more by one than the Handle of current ObjectId for any object/entity in Database.
In "pure" ObjectARX there is a function acdbEntNext - it can be used in .NET with help of P/Invoke but it return id only for entities (Entity) not for objects (DBObject)
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
Fredrik.Larsen
Message 5 of 5 (142 Views)
01-09-2013 05:14 AM in reply to: Alexander.Rivilis
I think this could get too ugly too fast so I am stepping away from this approach. If someone deletes an object in the dwg you loose all control of what the next object is supposed to be and that is no good. Thanks anyways.
