.NET
182 Views, 1 Reply
.Net problem
Hi there,
I hope somebody can help me in this problem.
I am using visual C# Express and SQL Server Express in windows XP in my local pc. I had build a small program just to check if it is working when i call it from AutoCAD. it gives me an error that "the database cannot be opened it has been located in UNC share".
when i click on continue it opens the form but it does not retrieve the data from the SQL Server.
and there is another thing i think its related to the same problem,
when i restart my pc a message box appears it says that
" The application attempted to perform an operation not allowed by the security policy. The operation required the securityException. To grant this application the required permission please contact your system administration tool.
Request for the permission of type
System.Security.Permissions.SecurityPermission, mscorlib,
Version=1.0.5000.0, Culture=neutral,
PublicKeyToken=b77a5c561934e089 failed."
this is the whole thing. please can anybody help?
Note: when i use another program that is not connected to a database everything is running without any problem.
sorry for my bad english 🙂
and thanks in advance.
1 REPLY 1
control panel > administrative tools > Microsoft .NET Framework 1.1
Configuration
Tim
http://www.theswamp.org/~tim/pyacaddotnet/
wrote in message news:5147062@discussion.autodesk.com...
Hi there,
”Boost
