.NET
Nested block position in model/paper space.
12 REPLIES 12
Message 1 of 13
coralie.jacobi
981 Views, 12 Replies
Hi,  I need to gather objects on a specivied layername within model_space in C#.
How do I add a fileter to my filtervalues to only grab model_space objects.
TypedValue
[] filterValues = new[] { newTypedValue((int)DxfCode.LayerName, LayerName.ToUpper()) };
SelectionFilter filter = newSelectionFilter(filterValues);
PromptSelectionResult foundBlocks = this.ed.SelectAll(filter);
SelectionSet currSS = foundBlocks.Value;
or
how to I check after I get the object and check the blockname
currEnt = (Entity)objID.GetObject(OpenMode.ForWrite);
if (currEnt.BlockName != "*Model_Space")
Please if someone could give me some guidence with the syntax.
thanks
12 REPLIES 12
Message 2 of 13
_gile
in reply to: coralie.jacobi
TypedValue[] filterValues = new[]
newTypedValue(8, LayerName),
new TypedValue(410, "Model")
Gilles Chanteau
GileCAD
GitHub
Message 3 of 13
coralie.jacobi
in reply to: _gile
thanks Gilles,
I've changed my code to this
TypedValue[] filterValues = new[] { new TypedValue(8, LayerName.ToUpper()), new TypedValue(410, "Model") };
but it still is picking up my object in paper space? not sure why it's not working. Any ideas? this seems simple enough, what am I doing wrong?
Message 4 of 13
have tried the following too with no success, based on the DXF code for model_space in the Autodesk documentation
TypedValue[] filterValues = new[] { newTypedValue(8, LayerName.ToUpper()), newTypedValue(67, 0) };
Message 5 of 13
DiningPhilosopher
in reply to: _gile
Hi Gile.
Not sure what localized version of AutoCAD the OP is using, but the name of the Model tab is localized, and there's no API I know if in the SymbolUtilityServices class that provides that, so you have to open the Layout to get the localized name in order to use it with a selection filter.
An example:
http://forums.autodesk.com/t5/NET/Send-Command-Executes-after-exiting-command-method/m-p/3882929/hig...
Message 6 of 13
Ertqwa
you could try 'SymbolUtilityServices.GetBlockModelSpaceId(database)'.
Example (AutoCAD 2012):
 [CommandMethod("TestLayerAndLayout")]
        public void TestLayerAndLayout()
            Document objDocument;
            TypedValue[] objTypedValueList = null;
            SelectionFilter objSelectionFilter = null;
            PromptSelectionResult objPromptSelectionResult = null;
            SelectionSet objSelectionSet = null;
            Entity entItem;
            try
                // Get document.
                objDocument = CADS.Application.DocumentManager.MdiActiveDocument;
                using (Transaction objTransaction = objDocument.Database.TransactionManager.StartTransaction())
                    // Create a TypedValue array to define the filter criteria.
                    objTypedValueList = new TypedValue[1];
                    objTypedValueList.SetValue(new TypedValue((int)DxfCode.LayerName, "0"), 0);
                    objSelectionFilter = new SelectionFilter(objTypedValueList);
                    // Select all.
                    objPromptSelectionResult = objDocument.Editor.SelectAll(objSelectionFilter);
                    if (objPromptSelectionResult.Status == PromptStatus.OK)
                        // Get selection set.
                        objSelectionSet = objPromptSelectionResult.Value;
                        // Loop selection set.
                        foreach (SelectedObject objSelectedObject in objSelectionSet)
                            if (objSelectedObject != null)
                                // Get entity.
                                entItem = objTransaction.GetObject(objSelectedObject.ObjectId, OpenMode.ForRead) as Entity;
                                if (entItem != null)
                                    if (entItem.OwnerId == SymbolUtilityServices.GetBlockModelSpaceId(objDocument.Database))
                                        objDocument.Editor.WriteMessage("\n Entity {0} is in modelspace.", entItem.GetType().ToString());
                                    else
                                        objDocument.Editor.WriteMessage("\n Entity {0} is NOT in modelspace.", entItem.GetType().ToString());
                                else
                                    objDocument.Editor.WriteMessage("\n One of the selected items is NULL and could not be processed.");
                            else
                                objDocument.Editor.WriteMessage("\n One of the selected objects is NULL and could not be processed.");
                    objTransaction.Commit();
            catch (System.Exception Ex)
                CADS.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Error testing if objects are in modelspace (layer 0 only): " + Ex.ToString());
Message 7 of 13
Hallex
I think the reason if this fail on your filter is not indexed right
TypedValue[] filterValues = new TypedValue[2]
Message 8 of 13
DiningPhilosopher
in reply to: Hallex
You don't pass an index for the array size when you initialize it with values.
Message 9 of 13
Finally getting back to this problem. I only get time to program here and there.
So, after people's suggestions this is what I have and it still keeps picking up the darn block in paperspace. I added the If statement to try and catch it using the symbolutilityservice but they all fall into the true part of the If. I have attached a sample drawing of what I'm working with, just in case that helps. I can't believe this is so difficult to resolve....
There are currently three blocks in the drawing, 2 in modelspace, 1 in paperspace. My currSS.Count returns 3, and all 3 fall into the true statement of the CurrEnt.OwnerID == SymbolUtilityServices.GetBlockModelSpaceId(this.dwgDB)
Any help or suggestions is greatly appreciated!!!
Happy New Years to everyone!
cj
 using (Transaction trans = this.dwgDB.TransactionManager.StartTransaction())
                BlockTableRecord btr = null;
                try
                    //  Get all objects on the databox layer in model space.
                    TypedValue[] filterValues = new TypedValue[3]
                    new TypedValue(0, "INSERT"), new TypedValue(8, LayerName.ToUpper()),new TypedValue(410, "Model")
                    SelectionFilter filter = new SelectionFilter(filterValues);
                    if (currSS != null && currSS.Count > 0)
                        Entity currEnt;
                        BlockReference blockRef;
                        ObjectId[] objs = currSS.GetObjectIds();
                        foreach (ObjectId objID in objs)
                            if (currEnt.OwnerId == SymbolUtilityServices.GetBlockModelSpaceId(this.dwgDB))
                                this.ed.WriteMessage("\n Entity {0} is in modelspace.", currEnt.GetType().ToString());
                            else
                               this.ed.WriteMessage("\n Entity {0} is NOT in modelspace.", currEnt.GetType().ToString());
                            if (currEnt is BlockReference)
                                blockRef = (BlockReference)currEnt;
Message 10 of 13
SENL1362
Please try this:
        [CommandMethod("SME")]
        public static void SelectModelspaceEntities()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                TypedValue[] filterValues = new TypedValue[]
                    new TypedValue((int)DxfCode.Start, "INSERT"),
                    new TypedValue((int)67, 0)    //Modelspace::67=0, Paperspace::67=1
                PromptSelectionResult foundBlocks = ed.SelectAll(filter);
                if (foundBlocks.Status!=PromptStatus.OK)
                    return;
                foreach(ObjectId id in foundBlocks.Value.GetObjectIds())
                    ed.WriteMessage("\n{0}", id.ObjectClass.DxfName);
                    BlockReference br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
                    ed.WriteMessage("\t{0}, {1}", br.Name, br.BlockName);
                tr.Commit();
Message 11 of 13
coralie.jacobi
in reply to: SENL1362
Thanks for the response and the sample code.
I've tried it and I get an error on the foundBlocks.status? Not sure what the issue is.
Message 12 of 13
SENL1362
Just tried it on the previous supplied Test.dwg without any problem.
These are the results:
Command: SME
INSERT HA-5, *Model_Space
INSERT HA-2, *Model_Space
Command: <Switching to: Layout1>
Regenerating layout.
Regenerating model - caching viewports.
Command: SPE
INSERT HA-2, *Paper_Space
           [CommandMethod("SPE")]
            public static void SelectPaperspaceEntities()
                    //new TypedValue((int)DxfCode.LayerName, "0"),
                    new TypedValue((int)67, 1)    //Modelspace::67=0, Paperspace::67=1
                    if (foundBlocks.Status != PromptStatus.OK)
                        return;
                    foreach (ObjectId id in foundBlocks.Value.GetObjectIds())
                    tr.Commit();
                        return;
                    tr.Commit();
Message 13 of 13
coralie.jacobi
Well progress, I can get it to work as a command by itself, but as soon as I make it a function and run it within the rest of the code, it finds the block in paperspace?
”Boost
