.NET
phives
Message 1 of 15 (271 Views)
Need help with code. I'm new to all this
271 Views, 14 Replies
08-25-2012 05:01 PM
I'm trying to use this code I founf here in the forum. What I can't figure out is where does it open the drawing and how do I pass it the ObjectID.
PublicSub SetAttribute(ByVal BlockID As Autodesk.AutoCAD.DatabaseServices.ObjectId, ByVal blckname AsString, ByVal AttTag AsString, ByVal AttVal AsString)
Dim MyDb AsDatabase = Application.DocumentManager.MdiActiveDocument.Database
If BlockID.IsNull ThenExit SubTryUsing myTrans AsTransaction= MyDb.TransactionManager.StartTransaction
Dim myBlckRef AsBlockReferenceDim myAttColl AsAttributeCollectionDim myBlckTable AsBlockTableRecord
myBlckRef = BlockID.GetObject(
OpenMode.ForWrite)
If myBlckRef.IsDynamicBlock Then
myBlckTable = myTrans.GetObject(myBlckRef.DynamicBlockTableRecord,
OpenMode.ForRead)
Else
myBlckTable = myTrans.GetObject(myBlckRef.BlockTableRecord,
OpenMode.ForRead)
EndIfIfString.Compare(myBlckTable.Name, blckname, True) = 0 Then
myAttColl = myBlckRef.AttributeCollection
Dim myEnt As Autodesk.AutoCAD.DatabaseServices.ObjectIdDim myAttRef As Autodesk.AutoCAD.DatabaseServices.AttributeReferenceForEach myEnt InmyAttColl
myAttRef = myEnt.GetObject(
OpenMode.ForWrite)
IfString.Compare(myAttRef.Tag, AttTag, True) = 0 Then
myAttRef.TextString = AttVal.ToString
EndIfNextEndIf
myTrans.Commit()
EndUsingCatch ex AsExceptionEndTryEndSub
Alfred.NESWADBA
Message 2 of 15 (253 Views)
Re: Need help with code. I'm new to all this
08-26-2012 01:07 AM in reply to: phives
It does not open the drawing, it uses the active document (currently loaded and activated DWG).
Sorry not to understand that. The answer "you call this sub and transfer the objectid by adding it as the first parameter to the calling line-code" will not be what you are looking for, I guess.
- alfred -
PS: to make your code readable within the threads here you should use the icon  in the answering-dialog. Otherwise you see your code gets really unstructured and so useless (spaces and cr missing after pasting your lines).
Alfred NESWADBA
phives
Message 3 of 15 (240 Views)
08-26-2012 05:14 AM in reply to: Alfred.NESWADBA
I want to create a routine that looks like this.
Sub EditAttribute(DWGNAME, BLOCKNAME, ATTRIBUTENAME, ATTRIBUTEVALUE)
The routine will open the specified drawing, find the block and attribute and write a new value in.
Alfred.NESWADBA
Message 4 of 15 (235 Views)
08-26-2012 05:25 AM in reply to: phives
and when the block (blockreference) is inserted multiple times in one drawing (e.g. 1 in each layout and 3 in the modelspace)? Which one should then be modified?
- alfred -
Alfred NESWADBA
phives
Message 5 of 15 (234 Views)
08-26-2012 05:27 AM in reply to: Alfred.NESWADBA
Each of our blocknames are unique. That's why we do it that way.
Alfred.NESWADBA
Message 6 of 15 (225 Views)
08-26-2012 07:12 AM in reply to: phives
find attached the code (and a sample drawing), it's not really tested, so be careful :smileywink:
- alfred -
Alfred NESWADBA
phives
Message 7 of 15 (221 Views)
08-26-2012 07:15 AM in reply to: Alfred.NESWADBA
Tx. will try it.....
phives
Message 8 of 15 (205 Views)
08-26-2012 10:06 AM in reply to: phives
I'm getting this error.....
Method 'GetEnumerator' in type 'Autodesk.AutoCAD.DatabaseServices.BlockTable' from assembly 'acdbmgd, Version=18.1.0.0, Culture=neutral, PublicKeyToken=null' does not have an implementation.
Alfred.NESWADBA
Message 9 of 15 (202 Views)
08-26-2012 10:20 AM in reply to: phives
upload your test-drawing and your call-parameters.
But I think it's anything like wrong version of the *mgd*.dll you are referencing ==> what os and what AutoCAD-version (and vertical product) do you work with?
- alfred -
Alfred NESWADBA
phives
Message 10 of 15 (201 Views)
08-26-2012 10:25 AM in reply to: Alfred.NESWADBA
fillBlock("C:\Users\PAUL\Desktop\B-03-J-H135.dwg", "RO", "CAB", "UUUU")
ACAD2010. I downloaded the ObjectARX2011. The dll's are there.
BTW. You know that I am doing this from a standalone EXE.
You are not logged in.
Ask the Community
