NETLOAD and ^P
NETLOAD and ^P
Ertqwa
NETLOAD and ^P
Ertqwa
Hello forum,
I'm guessing an easy question, but can't find an answer.
If I use NETLOAD in a macro between ^P's, I still see "NETLOAD Assembly file name: ..." in the text window, and then a 'nil' on the next line:
Macro:
^C^C^P(command "NETLOAD" "MyLibrary.dll")^P;MyCommand
Is there a way to supress the text and the nil in AutoCAD's text window, using NETLOAD?
Thank you.
Simple, don't use NETLOAD 🙂
Use this utility to demand load your net app, should solve your problem.
HomeBoy Out
chiefbraincloud
Turn CMDECHO off (0), that got rid of exerything but the "nil"
If you use VL-CMDF instead of COMMAND it will return T instead of nil
For whatever reason, when I call NETLOAD from a MNL (menu lisp) file, none of it shows up (with CMDECHO = 0).  I don't even toggle the MENUECHO setting.
Just to make sure you realize, ^P is a TOGGLE, which means that if the user already has it set to suppress the echo, the your button will override that and make it echo.
Ertqwa
Great, thanks I will try it!
