• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    Ertqwa
    NETLOAD and ^P
    220 Views, 3 Replies
    10-22-2011 12:42 PM
    Hello forum,
    I'm guessing an easy question, but can't find an answer.
    If I use NETLOAD in a macro between ^P's, I still see "NETLOAD Assembly file name: ..." in the text window, and then a 'nil' on the next line:
    Macro:
    ^C^C^P(command "NETLOAD" "MyLibrary.dll")^P;MyCommand
    Is there a way to supress the text and the nil in AutoCAD's text window, using NETLOAD?
    Thank you.
    Please use plain text.
    Active Contributor
    Re: NETLOAD and ^P
    10-23-2011 08:19 PM in reply to: Ertqwa
    Simple, don't use NETLOAD :smileyhappy:
    Use this utility to demand load your net app, should solve your problem.
    HomeBoy Out
    chiefbraincloud
    Re: NETLOAD and ^P
    10-24-2011 01:32 PM in reply to: Ertqwa
    Turn CMDECHO off (0), that got rid of exerything but the "nil"
    If you use VL-CMDF instead of COMMAND it will return T instead of nil
    For whatever reason, when I call NETLOAD from a MNL (menu lisp) file, none of it shows up (with CMDECHO = 0).  I don't even toggle the MENUECHO setting.
    Just to make sure you realize, ^P is a TOGGLE, which means that if the user already has it set to suppress the echo, the your button will override that and make it echo.
    Valued Contributor
    Ertqwa
    Re: NETLOAD and ^P
    10-26-2011 01:22 PM in reply to: chiefbraincloud
    Great, thanks I will try it!
