.NET
_gile
Message 11 of 13 (114 Views)
Re : .NET training labs
08-06-2012 12:14 PM in reply to: theEntity
theEntity,
Sorry if I offend you, this was not at all my intention (appologies for my poor English too).
The TryCast() method try to cast the DBObject returned by GetObject() in the specified type (Curve) and returns Nothing if the cast fails.
Then this is checked with the "IsNot Nothing" expression:
If ent IsNot Nothing AndAlso ent.ExtensionDictionary.IsValid Then
This works fine for me and correct the 'bug' I reported.
If you still have a problem, please tell how it occurs (which command is running and what you're doing in the autoCAD Editor) and which code line fires the exception.
About Dictionaries, they're usefull to store data within the Database (NOD children) or within a DBObject (extension dictionaries). These data will be available after closing and re-opening the drawing.
Gilles Chanteau
theEntity
Message 12 of 13 (111 Views)
08-06-2012 12:33 PM in reply to: _gile
yes thanks _gile   . no offence taken
i learn myself and have only the forum to help if i get stuck.  i understand casting but the solution is more apparent for you because you have lots of experience
i made the change you suggest and it seems to validate correctly now..
much thx
regards
_gile
Message 13 of 13 (96 Views)
08-06-2012 01:41 PM in reply to: theEntity
Another way (cheaper because the entity type is checked befor opening it) is to use the ObjectId.ObjectClass property:
    Public Sub MyInputMonitor(ByVal sender As Object, ByVal e As PointMonitorEventArgs)
        ' first lets check what is under the Cursor
        Dim fullEntPath() As FullSubentityPath = e.Context.GetPickedEntities()
        ' create a RXClass instance for the Curve class
        Dim curveClass As RXClass = RXClass.GetClass(GetType(Curve))
        ' check if there's something under the cursor and if it's derived from Curve
        If fullEntPath.Length > 0 AndAlso _
            fullEntPath(0).GetObjectIds(0).ObjectClass.IsDerivedFrom(curveClass) Then
            ' start a transaction
            Dim trans As Transaction = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction
            Try
                ' open the Entity for read, we  already know it's a Curve
                Dim ent As Curve = trans.GetObject(fullEntPath(0).GetObjectIds(0), OpenMode.ForRead)
                ' ok, so if we are over something - then check to see if it has an extension dictionary
                If (ent.ExtensionDictionary.IsValid) Then
Gilles Chanteau
