.NET
.NET framework 1.0
3 REPLIES 3
karenina
254 Views, 3 Replies
.NET framework 1.0
Hello there.
I am trying to develop a AutoCAD 2005 plugin using .NET framework 1.0 (C#). I am encountering some problems with the speed of my window forms (in a normal Windows application, everything is fine, but when using under AutoCAD, they are very very slow).
Is there any way I can solve this problem?
I cannot use 1.1, since it is a huge application and it is not my decision to take, so I have to find some way to solve the problem.
I tried telling AutoCAD through the config file that he must use v 1.0, but no improvements.
Any ideas?
Thanks a lot.
3 REPLIES 3
ChrisArps
in reply to: karenina
Are you referring to the first time the form shows or every time?
There will be a hit when the first dotnet code is run as the framework has to be loaded. You can see the same slowdown running the layer command for the first time in a new session.
I have a lot of dotnet forms in ADT/Autocad2005 and have no problems with speed versus a standalone .exe.
Chris Arps
karenina
Not only the first time, but all the time. My problem is actually more complex, since my plugin must log on to a server (which is also connected to a database). I have to get objects from the serverand show them to the user. I believe the low performance is because of the remoting connection with the server.
I am using the exact same window forms in the exact same way in an Windows Form Application and everything works fine.
Do you have any idea about this behaviour?
Thanks a lot for your quick answer.
ChrisArps
That should not be the case, code running from a dotnet dll should execute exactly as fast in Acad.exe or your own .exe.
There is something defintely funky going on, I use a database as well, but I am using disconnected recordsts. My database size is small enough that reading it into a dataset is not a problem.
I would suggest trying to narrow it down to a simple sample that can be sent to autodesk for analysis.
E.G. Create a .dll that shows the slowdown in acad.exe and also create an exe using the same .dll with no slowdown.
Chris Arps
”Boost
