.NET
Valued Contributor
raghulan
Message 1 of 5 (478 Views)
.NET c# unable to detaching FileNotFound xref without opening the drawing.
478 Views, 4 Replies
07-29-2012 02:09 AM
Hello Coders,
 I am new here, I am a bigginer.
Here is my issue.
I wanted to detach xrefs that having status File Not found from multiple drawings (fodlers and sub folders)
without opening the drawing file.
- I am able to get all the dwg files from folders and subfodlers.
- am able to find the xrefs that are working and the ones that arent
I am not able to detach the xrefs that are having the status FileNotfound.
I dont know how to get the objectIds of those xrefs. I tried several ways..please help me.
Here is my code:
[CommandMethod("Dref")]
public void detach_xref()
//get the document
Document Doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = Doc.Editor;
// Ask the user to select a folder
PromptResult res = ed.GetString("\nEnter the path of the folder: ");
string[] filepaths = Directory.GetFiles(res.StringResult, "*.dwg", SearchOption.AllDirectories);
int filecount = filepaths.Length;
ed.WriteMessage("\nScanning " + filecount + " files");
for (int i = 0; i < filecount; i++)
ed.WriteMessage("\n File Name : " + filepaths[i]);
//create a database and try to load the file
Database db = new Database(false, true);
using (db)
try
db.ReadDwgFile(filepaths[i], System.IO.FileShare.Read, false, "");
catch (System.Exception)
ed.WriteMessage("\nUnable to read the drawingfile.");
return;
db.ResolveXrefs(true, false);
XrefGraph xg = db.GetHostDwgXrefGraph(true);
int xrefcount = xg.NumNodes - 1;
if(xrefcount > 0)
using (Transaction tr = db.TransactionManager.StartTransaction())
ObjectIdCollection btcoll = new ObjectIdCollection();
for (int j = 1; i < xrefcount; i++)
XrefGraphNode xrNode = xg.GetXrefNode(j);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(xrNode.BlockTableRecordId, OpenMode.ForWrite);
if (xrNode.XrefStatus == XrefStatus.FileNotFound)
foreach (ObjectId id in btr)
db.DetachXref(id);
ed.WriteMessage("\nDetached successfully");
//transaction
tr.Commit();
Raghulan Gowthaman Cert IV TAA, B.E,.
Senior Technical Consultant | Developer - R&D
A2K Technologies Sydney
Web : www.a2ktechnologies.com.au
www.civil3dforum.com | www.e4forums.com
www.zcodia.com.au
www.raghulangowthaman.com
Valued Mentor
fieldguy
Message 2 of 5 (461 Views)
Re: .NET c# unable to detaching FileNotFound xref without opening the drawing.
07-30-2012 08:28 AM in reply to: raghulan
Try this.
ObjectID detachid = xrNode.BlockTableRecordId;
db.DetachXref(detachid);
That should be close - I have not coded C# in a while.
Valued Contributor
raghulan
Message 3 of 5 (421 Views)
08-09-2012 12:03 AM in reply to: raghulan
I tried I am getting another error
www.zcodia.com.au
ADN Support Specialist
Balaji_Ram
Message 4 of 5 (393 Views)
08-10-2012 04:31 AM in reply to: raghulan
You need to be more specific about the kind of issue you are having.
Here is the code sample that I posted in response to your other post on the same topic :
This sample code can only detach external references directly inserted in the drawing (not nested ones).
		[CommandMethod("DetachXref")]
			string mainDrawingFile = @"C:\Temp\Test.dwg";
			Database db = new Database(false, false);
			using (db)
				try
					db.ReadDwgFile(mainDrawingFile, System.IO.FileShare.ReadWrite, false, "");
					return;
				bool saveRequired = false;
					int xrefcount = xg.NumNodes;
					for (int j = 0; j < xrefcount; j++)
						String nodeName = xrNode.Name;
							ObjectId detachid = xrNode.BlockTableRecordId;
							saveRequired = true;
							break;
					tr.Commit();
				if(saveRequired)
					db.SaveAs(mainDrawingFile, DwgVersion.Current);
Balaji
Developer Technical Services
Autodesk Developer Network
Valued Contributor
raghulan
Message 5 of 5 (384 Views)
08-13-2012 01:43 AM in reply to: Balaji_Ram
Thanks Balaji,
Genious..!! solved my issue...
www.zcodia.com.au
You are not logged in.
Ask the Community
